License issue in Cisco 3900
manoj.kumar0074
Can any one suggest me that the license is an evaluation or original in the router.
Output is shown below:
sh licen all
License Store: Primary License Storage
StoreIndex: 0 Feature: datak9                            Version: 1.0
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
StoreIndex: 1 Feature: ipbasek9                          Version: 1.0
StoreIndex: 2 Feature: securityk9                        Version: 1.0
License Store: Evaluation License Storage
StoreIndex: 0 Feature: securityk9                        Version: 1.0
License Type: Evaluation
License State: Inactive
    Evaluation total period: 8  weeks 4  days
    Evaluation period left: 8  weeks 4  days
License Priority: None
StoreIndex: 1 Feature: uck9                              Version: 1.0
License State: Active, Not in Use, EULA not accepted
StoreIndex: 2 Feature: datak9                            Version: 1.0
StoreIndex: 3 Feature: gatekeeper                        Version: 1.0
StoreIndex: 4 Feature: SSL_VPN                           Version: 1.0
License Count: 200/0/0  (Active/In-use/Violation)
StoreIndex: 5 Feature: SNASw                             Version: 1.0
skarthic
http://www.cisco.com/en/US/partner/docs/ios/csa/configuration/guide/csa_overview.html
Please check the above link for more info on univ images
You have permanent licences for the above features(data,ipbas,security) and you have evaluation licenense for the other features.
But you have not turned on the other license. You can use the other license whenever you require them for a period
of 8 week 4 days for each of them.
R.S.Karthic.
Hi Karthic,
It's really knowledgable for me but I had a little bit confusion about the output which i had posted.There is datak9 services in both ( permanent and evalution).
MPSPRI#sh licen all
So can you explain me what is different between both of them?
This is quite normal..
MPSPRI#sh licen all
You can see that the above license is currently used because  it is active,in use.
Also this is a permanent license
And since the priority is medium this license is being used.
The evaluation "datak9" license priority is "none" and hence is not used.
Normally we get the  IOS with evaluation license for all features for 60 days.
you have activated a "datak9" license that is permanent..
Reply if you have any queries..
Karthic.R.S.
Adeel S Hussain
Help will be appreciated our phones getting
Registration rejected. Max phone reached
Router#show telephony-service license
License Supported:
cme-srst: Registered, Not In Use. Handle: 0x0
Maximum User License: 0
CSL license count: 0
CSL Requested User License: 0
Used User License: 0
Available User License: 0
Max Users Provisioned (ephone + pool): 365
Allowance - Extra user license: 15
temp_license_expired_event: 0
license_installed_event: 0
license_count_change_event: 0
eula_not_accepted: 0
license_check_approved: 0
license_check_denied: 407
Possible License Denial reason: No license installed or temporary license expired.
