line protocol down
hello all ... when i check the interface in Router ASR 1006 .. i see the line protocol down .... and the interface down ... what mean that ????
38 Replies 38
yeah .. i use just GIPC 1000Base SX .... i not use 1000BaseBX10U
Can you paste show interface, from the interfaces that you used for the loopback test.
Dan
ok ... wait me some minute
NAS#show interfaces gigabitEthernet 2/1/0 GigabitEthernet2/1/0 is down, line protocol is down   Hardware is SPA-10X1GE-V2, address is b414.8904.1a90 (bia b414   MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,      reliability 255/255, txload 1/255, rxload 1/255   Encapsulation ARPA, loopback not set   Keepalive not supported   Full Duplex, 1000Mbps, link type is auto, media type is 1000Ba   output flow-control is on, input flow-control is on   ARP type: ARPA, ARP Timeout 04:00:00   Last input never, output never, output hang never   Last clearing of "show interface" counters never   Input queue: 0/375/0/0 (size/max/drops/flushes); Total output   Queueing strategy: fifo   Output queue: 0/40 (size/max)   5 minute input rate 0 bits/sec, 0 packets/sec   5 minute output rate 0 bits/sec, 0 packets/sec      0 packets input, 0 bytes, 0 no buffer      Received 0 broadcasts (0 IP multicasts)      0 runts, 0 giants, 0 throttles      0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored      0 watchdog, 0 multicast, 0 pause input      0 packets output, 0 bytes, 0 underruns      0 output errors, 0 collisions, 1 interface resets      0 unknown protocol drops      0 babbles, 0 late collision, 0 deferred      0 lost carrier, 0 no carrier, 0 pause output      0 output buffer failures, 0 output buffers swapped out
Try to paste again.
Dan
GigabitEthernet2/1/0 is down, line protocol is down   Hardware is SPA-10X1GE-V2, address is b414.8904.1a90 (bia b414.8904.1a90)   MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,      reliability 255/255, txload 1/255, rxload 1/255   Encapsulation ARPA, loopback not set   Keepalive not supported   Full Duplex, 1000Mbps, link type is auto, media type is 1000BaseBX10U   output flow-control is on, input flow-control is on   ARP type: ARPA, ARP Timeout 04:00:00   Last input never, output never, output hang never   Last clearing of "show interface" counters never   Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0   Queueing strategy: fifo   Output queue: 0/40 (size/max)   5 minute input rate 0 bits/sec, 0 packets/sec   5 minute output rate 0 bits/sec, 0 packets/sec      0 packets input, 0 bytes, 0 no buffer      Received 0 broadcasts (0 IP multicasts)      0 runts, 0 giants, 0 throttles      0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored      0 watchdog, 0 multicast, 0 pause input      0 packets output, 0 bytes, 0 underruns      0 output errors, 0 collisions, 1 interface resets      0 unknown protocol drops      0 babbles, 0 late collision, 0 deferred      0 lost carrier, 0 no carrier, 0 pause output      0 output buffer failures, 0 output buffers swapped out
As i wrote earlier : you have an BX not  SX SPF.
Dan
well .. dear Dan look this is another interface .. i not plug anything in it .. i mean i not put any media in the port   GigabitEthernet2/1/1 is down, line protocol is down   Hardware is SPA-10X1GE-V2, address is b414.8904.1a90 (bia b414.8904.1a90)   MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,      reliability 255/255, txload 1/255, rxload 1/255   Encapsulation ARPA, loopback not set   Keepalive not supported   Full Duplex, 1000Mbps, link type is auto, media type is 1000BaseBX10U   output flow-control is on, input flow-control is on   ARP type: ARPA, ARP Timeout 04:00:00   Last input never, output never, output hang never   Last clearing of "show interface" counters never   Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0   Queueing strategy: fifo   Output queue: 0/40 (size/max)   5 minute input rate 0 bits/sec, 0 packets/sec   5 minute output rate 0 bits/sec, 0 packets/sec      0 packets input, 0 bytes, 0 no buffer      Received 0 broadcasts (0 IP multicasts)      0 runts, 0 giants, 0 throttles      0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored      0 watchdog, 0 multicast, 0 pause input      0 packets output, 0 bytes, 0 underruns      0 output errors, 0 collisions, 1 interface resets      0 unknown protocol drops      0 babbles, 0 late collision, 0 deferred      0 lost carrier, 0 no carrier, 0 pause output      0 output buffer failures, 0 output buffers swapped out     it read media .. from where this media ????
Media type is from the type of the port/module.
If you want to test the 1000BaseBX10U you will need a 1000BaseBX10D SFP.
Dan
