ASR1006 help
hello dear ...  i have cisco router ASR 1006 .... i need to create PPPOE  connection  via Ethernet ... can i do that ??? and can do that on the management port ???? and what is the type of adapter that use in the Giga Ethernt  interface to connect it to fiber ????     hint :-  my interface hardware SPA-10X1GE-V2      Regards ...
7 Replies 7
please .. some body can help me with my problem ???
You cant use mgt port for data . IPv4, IPv6, and ARP are the only routed protocols supported for the interface.
1. Detailed information on mgt port - http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/Management_Ethernet.html
2. Here is the PPPoE configure guide for  XE Release 2.2.1
thank you very much dear .. but where the link for the PPPOE procedure ????
i am very grateful for u'r help ... i reed the articular it is good .. but you can summarize just the steps of configuration the PPPOE over Ethernet or VLAN only in some point please or in text file and attach it   dear can continue with you via emial please ????  regards ....
any help ?????
