01-10-2008 10:58 PM - edited 03-03-2019 08:13 PM
PLease tell me what is the difference between ...
Serial1/0 is up, line protocol is down (Looped) aud
Serial1/0 is up, line protocol is up (looped)
somnath
01-10-2008 11:40 PM
Dear Somnath, [Pls Rate if HELPS]
The following are the steps required to perform loopback testing: (Answers for your Question) :
Step 1 Put the remote CSU or DSU into remote loopback mode
Step 2 Using the show interfaces serial exec command, determine whether the line protocol remains up with the status line indicating "Serial x is up, line protocol is up (looped)," or if it goes down with the status line indicating "line protocol is down."
Step 3 If the line protocol remains up (looped), the problem is probably at the remote end of the serial connection (between the remote CSU/DSU and the remote router). Perform both local and remote tests at the remote end to isolate the problem source.
Step 4 If the line status changes to "line protocol is down" when remote loopback mode is activated, make certain that ones density is being properly maintained. The CSU/DSU must be configured to use the same framing and coding schemes used by the leased-line or other carrier service (for
example, ESF and B8ZS).
Step 5 If problems persist, contact your WAN
service organization
PLS RATE if HELPS
Best Regards,
Guru Prasad R
01-11-2008 11:48 AM
I have experienced that :
1) if encapsulation is hdlc then the line protocol shows up and looped
2) if encapsulation is ppp then the line protocol show down and looped
RATE HELPFUL POST
01-12-2008 04:40 AM
Thanks!!
