Load Balancing across multiple ADSL Link
jain.nitin
Level 3
Level 3
Hi Techies,
Please help to configure load balancing between four adsl links connected to a router.
How can I achieve load balancing between these link. getting dynamic IPs on each link.
8 Replies 8
devang_etcom
Level 7
Level 7
hi nitin...
will you give me the connectivity diagram... where all the four ADSL line connection end... its on different router or on the same router...
so as per your connectivity you can use various tools like MLPPP, HSRP or static routes...
rate this post if it helps
regards
Devang
Hi Devang,
Thanks for reply. It is connected on a single router.
i think here you can do it by configuring 4 default route with the same AD... so you can have loadbalancing among all the link...
other thing you can have MLPPP but this configuration need point to point connection so you have to go for PPPoE or PPPoA...then you can create virtual templet or you can use the MLPPP... i m not sure about it but check it out... otherwies you can do it using the four default route with the same AD...
hope this helps you
regards
Devang
rajinikanth
Level 3
Level 3
Do you have 4 adsl modems connected to 4 interfaces on router same router
yeah...
Hi ,
About getting dynamic Ips on ur router is possible by setting your adsl modems to bridge mode.
Try using this config to create dialer interface on ur router:
interface FastEthernet0/1 (depending on the inteface ur modem connected)
description ADSL Internet connection
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
and
interface Dialer1
ip address dhcp
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname
ppp chap password 7
Try configuring a single dialer interface for each connection .
Tell me if this helps
Raj
in addition to the other posts, here is a sample configuration for 4 links on the same router configured for load balancing. At the bottom of this post, you can find a couple remarks regarding this configuration:
R1 Configuration
ip cef
ip nat inside
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no ip route-cache
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface ATM0.2 point-to-point
no ip route-cache
pvc 0/38
dialer pool-member 2
interface ATM0.3 point-to-point
no ip route-cache
pvc 0/38
dialer pool-member 3
interface ATM0.4 point-to-point
no ip route-cache
pvc 0/38
dialer pool-member 4
interface Dialer1
description ISP1_Connection_1
ip address dhcp
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname USERNAME
ppp chap password 0 PASSWORD
ppp pap sent-username USERNAME password PASSWORD
interface Dialer2
description ISP1_Connection_2
ip address dhcp
ip mtu 1452
encapsulation ppp
dialer pool 2
dialer-group 1
interface Dialer3
description ISP1_Connection_3
ip address dhcp
ip mtu 1452
encapsulation ppp
dialer pool 3
dialer-group 1
interface Dialer4
description ISP1_Connection_4
ip address dhcp
ip mtu 1452
encapsulation ppp
dialer pool 4
dialer-group 1
ip nat inside source route-map ISP1_Connection_1 interface Dialer1 overload
ip nat inside source route-map ISP1_Connection_2 interface Dialer2 overload
ip nat inside source route-map ISP1_Connection_3 interface Dialer3 overload
ip nat inside source route-map ISP1_Connection_4 interface Dialer4 overload
access-list 1 permit 192.168.1.0
route-map ISP1_Connection_1 permit 10
match ip address 1
match interface Dialer1
route-map ISP1_Connection_2 permit 10
match ip address 1
match interface Dialer2
route-map ISP1_Connection_3 permit 10
match ip address 1
match interface Dialer3
route-map ISP1_Connection_4 permit 10
match ip address 1
match interface Dialer4
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
ip route 0.0.0.0 0.0.0.0 Dialer3
ip route 0.0.0.0 0.0.0.0 Dialer4
dialer-list 1 protocol ip permit
The following applies:
- the use of four static routes will allow load-balancing over the four links and provide redundancy at the same time
- the NAT configuration will dynamically choose the NAT'ed address depending on which interface CEF has been chosen to send the packet out of
- enabling CEF with four default routes will by default load balance per-destination, which means for every source and destination address pair, CEF creates a hash and chooses one of the routes in the routing table.
- enabling CEF on a router will load balance outgoing traffic only, not incoming traffic. If your ISP uses Cisco, you could ask for the ISP to enable CEF on their end as well, which would result in inbound load balancing.
To verify load balancing, use the EXEC command:
sh ip cef 0.0.0.0
Hope this makes sense...
GNT
@GNT: you have 4 lines over 1 ATM IF? i'm not a technician .. but how is that possible?
