router on a stick
pacsniffing
Hi;
can anyone point me in the direction of papers on the configuration of router on a stick? both the router side and the switch side. thanks in advance.
devang_etcom
Level 7
Level 7
hi you can have information on this link:http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/rel_5_2/layer3/routing.htm
rate this post if it helps
letme know if you want more hlep
regards
Devang
devang_etcom
Level 7
Level 7
this will be more easy:http://www.cisco.com/warp/public/473/50.shtml
regards
Devang
Thanks for the suggestions Devang, in our setup we have 3700 that handles IVR, but what i was looking at is a router to do load balancing of a number of WAN links, sorry should have been more specific. I'll attach a document which should more clearly specify my needs; i've found manuals but none of them so far seem applicable to our current needs. the document was drafted in visio
rajinikanth
Level 3
Level 3
