Load balancing for remote sites with dynamic IPs
joseph.yuffa
My site router is connected to 2 remote routers thru Internet. Any ideas how can I set load balancing up if remote sites get their ip addresses from ISP's DHCP server?
paolo bevilacqua
Hi, look at the example:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
Keep the two default routes to have same weight if you want to load balance.
The example is not relevant to my case. Please see attached diagram for my topology. I need load sharing between destination routers B and C when accessing it from A
Sorry, can't see proprietary file format.
The remote router will have to begin the vpn via a dmvpn type setup.
You can also no not envrypt and just use poin-to-multipoint GRE with nhpr. This is also a DMVPN tecnique.
Then when you have routing information for the site over GRE tunnels, router will load share using the two lthat you will have set to be terminated at B and C. With dynamic routing, you will have redundancy as well.
