clear counter for controllers fa0/0 in c1841 router
jay77jay77
Like clear counter int fa0/0- is there any command to clear the counter under controllers fa0/0?
eg. im seeing these conuters under controller fa0/0:
Bytes_recvd 2349082481 Bytes_sent 2040588177 Frames_recvd 282629943
Frames_sent 209684194
total_bytes_RX 2349114885 Total_frames_RX 282630045
Bcast_frames_recvd 89338444
Mcast_frames_RX 23653742 CRC_err 0 Ovr_sized_frames 0
Fragments 0 Jabber 0 collision 0
9 Replies 9
guruprasadr
Level 7
Level 7
HI Jay, [Pls Rate if HELPS]
Use "clear controller" EXEC command to reset the T1 or E1 Controller.
Clear controller {t1 | e1} Slot/Port
Clear controller {t1 | e1} number
t1 = specifies the T1 Controller
e1 = specified the e1 controller
Slot/Port = Backplane slot number or port number on the interface.
number = Network Interface Module Number, in the range of 0 through 2.
Hope I am Informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
im asking about fastethernet i/f.
Sorry, i missed....Here follow the answers:
Use the clear interface fastethernet privileged EXEC command to reset the controller for a specified Fast Ethernet interface.
clear interface fastethernet number (Cisco 4500 and 4700 series routers)
clear interface fastethernet slot/port (Cisco 7200 and Cisco 7500 series routers)
clear interface fastethernet slot/port-adapter/port (Cisco 7500 series routers)
Pls RATE if HELPS
Best Regards,
Guru Prasad R
I think that clear counter < interface > already do that.
The counters not cleared are real-time counters, they increment as the traffic flows through the interface.
Sorry, controller-level counters cannot be cleared. Just use interface-level instead.
Pravin Phadte
Level 5
Level 5
clear counters fasteth0/0 would work.
Attached is the output of one of the routers.
Ah, good to know, it not always did.
none of the commands worked.
so i think no commands for that..just only a reboot can clear!!
tks
HI Jay, [Pls RATE if HELPS]
Normally, with a "reboot" my requirement of "Buffer Failures" & "Memory Failures" value has cleared.
May be i was thinking during my first POST itself, but i am not sure whether "reboot" might help for clearing the values of the interface you specified.
Try once and keep us updated.
Best Regards,
Guru Prasad R
