Load balancing on client side of VPN
patrickobrill
I am trying to set up 2 DSL connections and a cable connection in my home. I have been looking at load balancing routers, including 1751. However, I connect to work through Cisco VPN (VPN client version 4.8.01.0300). Will this tunnel be load balanced?
spremkumar
Level 9
Level 9
Hi Patrick
AFAIK you will be establishing the VPN tunnel with either one of the router and i dont think you will be able to load balance on the same..
regds
On the 1751 router I can add multiple DSL WIC cards which are then load balanced, so this is only one router. Please explain if the VPN tunnel will be load balances between the DSL WICs on the 1751 router or why not. Thank you, Pat
