01-18-2007 05:07 PM - edited 03-03-2019 03:25 PM
I'm trying to recover the password on a 2514 router in my lab at school. During boot I was only seeing what looked like encrypted data, and unable to get a break at a braud rate of 9600. When switched to 2400 braud rate, was finally able to read data and insert break. The confige register is 0xffff3902, when try to change it ask for cirfirm y/n. type y or yes and it won't change. any suggestions Thanks RS
01-18-2007 10:08 PM
Can you confirm whether you have followed the below link for recovering the password ?
regds
01-18-2007 11:44 PM
Hi there,
Here you are:
I've done it before smooth and easy.
HTH,
Mohamed Mahmnoud.
01-19-2007 04:17 AM
That config register value looks strange. Normally, a config register is only 4 Hex digits such as 0x2102.
01-19-2007 04:34 AM
You have to reset the router in order to config-register take effect.Without reload it will show you the older value.
Follow the link above and see if you faces and issues.
-amit singh
