load balancing with BGP- disabling AS-PATH comparison
nkariyawasam
I am configuring bgp between two AS. There are two links between them. One goes through another AS and the second is direct connection.
In order to install both routes ( for load sharing) I need to disable the comparison of AS-PATHs.
According to ddocumentation, the command
is "bgp bestpath as-path ignore". But on my 3662 router ( with IOS 12.4) doesn't have this command.
Is there any alternate way to ignore the comparison of AS-PATH s ?
anton.elita
hi,
you could prepend one path with your own AS, so that the AS-paths are of the same length. This could be done with route-map and set as-path prepend inside.
regards,
anton
often this will not work... the oldest route will win... still non-balanced path...
prepending should solve the issue with different AS_Path PA. Afterwards, one can use multipath feature.
please consider the following link for a complete eBGP multipath requirements:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml#bgpmpath
hope this helps- please rate if it does.
regards,
anton
