Load Sharing with the Loopback Address as a BGP Neighbor - BGP session down
I have one scenario. One end is using Cisco router and the other end using Juniper router have been configured eBGP Multihoming using loopback IP. At each router, two interface have been configured and both static route has been pointing to the eBGP loopback IP. The problem is, for example if the
1st interface/link down, the BGP also will down eventhough the 2nd interface/link up. By right for Multihoming BGP at least one physical link should be up to keep to BGP up. Any one have experienced this sort of problem before? Need some help. Thanks in advance!
arel
30 Replies 30
Did you capture traffic with EPC or RITE like I suggested as the debug is not an option because the traceroute working is not really indicating us what's happening .
Regards.
Alain.
