Load Sharing with the Loopback Address as a BGP Neighbor - BGP session down
I have one scenario. One end is using Cisco router and the other end using Juniper router have been configured eBGP Multihoming using loopback IP. At each router, two interface have been configured and both static route has been pointing to the eBGP loopback IP. The problem is, for example if the
1st interface/link down, the BGP also will down eventhough the 2nd interface/link up. By right for Multihoming BGP at least one physical link should be up to keep to BGP up. Any one have experienced this sort of problem before? Need some help. Thanks in advance!
arel
30 Replies 30
lgijssel
Level 9
Level 9
Having a look at some configuration would be helpful.
Cisco side should contain this:
neighbor 2.2.2.2 remote-as xxxx
neighbor 2.2.2.2 update-source loopback 0
neighbor 2.2.2.2 ebgp-multihop [ttl]
Are you sure both paths are working?
Verify both paths carefully, using static routes may not be the best way to create failover redundancy.
regards,
Leo
Hi Leo,
Thanks a lot for your feedback. Both path are working and all configuration you mention above already included. Please look example config below. If one link down the BGP will drop. Any idea what cause this problem? Thank you
CISCO BGP config
neighbor 2.2.2.2 description "SINGA-STM4x2"
neighbor 2.2.2.2 ebgp-multihop 2
neighbor 2.2.2.2 password 7 xxxxxx
neighbor 2.2.2.2update-source Loopback0
neighbor 2.2.2.2 activate
neighbor 2.2.2.2 remove-private-as
neighbor 2.2.2.2 soft-reconfiguration inbound
neighbor 2.2.2.2 prefix-list in-filter in
neighbor 2.2.2.2 prefix-list xxxxxx out
neighbor 2.2.2.2 route-map xxxxx in
neighbor 2.2.2.2 filter-list 1 out
ip route 2.2.2.2 255.255.255.255 x.x.x.33
ip route 2.2.2.2 255.255.255.255 x.x.x.21
Loopback0            1.1.1.1
Juniper BGP config
set routing-options static route 1.1.1.1/32 next-hop x.x.x.22
set routing-options static route 1.1.1.1/32 next-hop x.x.x.34
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 descriptionn "XXXX with Multihop-EBGP"
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 multihop ttl 2
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 local-address 2.2.2.2
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 import no-default
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 import no-smallprefixes
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 import rfc1918-dsua
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 import XXXXIN
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 import XXX-IN
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 family inet any prefix-limit maximum 1000
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 family inet any prefix-limit teardown 90
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 family inet any prefix-limit teardown idle-timeout forever
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 authentication-key "xxxxxx"
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 export no-default
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 export no-smallprefixes
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 export rfc1918-dsua
set protocols bgp group CUSTOMERS neighbor 1.1.1.1 peer-as XXXX
arel
What type of WAN link are you using?
Regards.
Alain.
Hi Alain,
Do you mean interface? POS interface. Thanks
arel
Yes and what encapsulation are you using?
Regards.
Alain.
encapsulation PPP
arel
Can you post output of sh ip route static and sh ip int br | exc una  when both links are up then when one is down
as well as sh run interface.
Regards.
Alain.
Gentlemen,
In addition to other requested information, would it be possible to post the (complete) output of the show ip bgp neighbor 2.2.2.2 command on the Cisco side?
Best regards,
Peter
Hi Guys,
Maybe later will do some failover test and capture debugging for both router to check BGP and TCP transaction. I think there is no wrong with the configuration right or am I missing any configuration? because when both links is up no issue arise...
Cisco interface config
interface POS7/1
description XXXXX
ip address X.X.X.22 255.255.255.252
no ip directed-broadcast
encapsulation ppp
ip route-cache flow sampled input
crc 32
pos framing sdh
pos flag s1s0 2
interface POS7/2
description XXXX
ip address X.X.X.34 255.255.255.252
encapsulation ppp
crc 32
pos framing sdh
pos flag s1s0 2
Juniper
- configuration is the same for other interface
> show configuration interfaces so-6/1/1
clocking external;
encapsulation ppp;
sonet-options {
    fcs 32;
    no-payload-scrambler;
unit 0 {
    description "XXXXX"
    family inet {
        rpf-check {
            fail-filter URPF-FILTER;
            mode loose;
        filter {
            input CFLOW;
        address x.x.x.21/30;
Arel
i'm just curious..erm could be this related to problem at lower layer? example on transmission issue?
arel
Hi,.
I think it's hard to answer without further info
But your config is good for Cisco and AFAIK on the Juniper side also.
Were you able to ping 2.2.2.2 from 1.1.1.1 when the failover occured and the BGP peering went down?
Regards.
Alain.
Hi Alain,
When one interface down,one interface up while BGP was down..ping to BGP neighbor was reach able. Thank you
i would also do a debug on the Juniper..i have seen things on a Juniper that are not so pretty..
Also do a deug for PPP, you never know it may prove something.
hth
rpf-check {
            mode loose;
        filter {
            input CFLOW;
Isn't it an ACL ? along with uRPF could it be the culprit?
Regards.
Alain.
