Local Route showed in routing table, however not configured
jbaros
Hello Team,
I have here curious case, I am seeing local routes in my routing table which is not configured on my router. See below:
Spoiler
L 10.51.38.129/32 is directly connected, GigabitEthernet0/0/2.950
L 10.51.38.150/32 is directly connected, GigabitEthernet0/0/2.950
L 10.51.38.151/32 is directly connected, GigabitEthernet0/0/2.950
L 10.51.38.152/32 is directly connected, GigabitEthernet0/0/2.950
L 10.51.38.153/32 is directly connected, GigabitEthernet0/0/2.950
L 10.51.38.154/32 is directly connected, GigabitEthernet0/0/2.950
L 10.51.38.155/32 is directly connected, GigabitEthernet0/0/2.950
L 10.51.38.157/32 is directly connected, GigabitEthernet0/0/2.950
But my interface is configured by another IP:
Spoiler
interface GigabitEthernet0/0/2.950
description --- admin to switch
encapsulation dot1Q 950
ip address 10.51.46.94 255.255.255.224 secondary
ip address 10.51.38.129 255.255.255.224
no ip redirects
no ip proxy-arp
end
Why there are such Local routes in my table? I would like to use them for switches management, however this not working until it is in routing table as L. ARP is showing that 10.51.38.150 has same MAC as router. I have tried restart interface, reconfigure, clear IP table.
How can I remove my not existing Local routes?
Thanks a  lot.
jbaros
Thank You for your answers, I have fixed it - by workaround. I have moved admin interface to redundant router, and now on new router it is working good, I dont see any non-existing IP addresses in my routing table.
But I didnt find out what caused the issue
5 Replies 5
there is issue with NAT I think
can you share the config of NAT you use?
Hello MHM,
I am not using NAT, but good point.
Spoiler
router1439#sh ip nat stat
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
Inside interfaces:
Hits: 1298166 Misses: 836454
Expired translations: 836312
Dynamic mappings:
nat-limit statistics:
max entry: max allowed 0, used 0, missed 0
In-to-out drops: 0 Out-to-in drops: 0
Pool stats drop: 0 Mapping stats drop: 0
Port block alloc fail: 0
IP alias add fail: 0
Limit entry add fail: 0
router1439#show ip nat translation
Total number of translations: 0
I also did check if those IP is configured, but not.
Spoiler
router1439#sh run | inc 10.51.38.150
router1439#
I will run lab and check, just for info.
first
you have hsrp run between two core ??
and there is no nat ? confirmed
and the proxy arp is disable ? please confirm
and there is no dhcp exclude for these IP in any router ? please confirm
Hello MHM,
Here are my replies:
you have hsrp run between two core ?? - NO for subinterface 950, for other sub interfaces I use HSRP
and the
proxy arp
is disable ? - YES,
no ip proxy-arp
on each interface including subinterfaces
and there is no dhcp exclude for these IP in any router ? NO DHCP for 10.51.38.128/27 at all, this is static range
Thank you for your checks.
jbaros
