During VLSM addressing, how do I configure a IP address range when a n
salon09
So the network ID I’m using is 192.150.3.0 /22. I’ve been asked to make an addressing scheme for 4 LANs
I’m confused as to how the host ranges work when the host number is large( all the online examples show a small host amount of bellow 255). Also since it’s 192, I’m working with class C CIDR values?
Say the largest LAN has 400 hosts. I use subnet mask /23 which in total hosts 512 hosts.
Now with my network host ranges, how would we write the range does the 3rd oclet change? Would this be 180.150.3.1 - 180.150.4.254?
balaji.bandi
Now with my network host ranges, how would we write the range does the 3rd oclet change? Would this be 180.150.3.1 - 180.150.4.254?  - do not believe this can be done.
example :
All 128 of the Possible /23 Networks for 192.150.*.*
192.150.0.0 192.150.0.1 - 192.150.1.254 192.150.1.255
192.150.2.0 192.150.2.1 - 192.150.3.254 192.150.3.255
192.150.4.0 192.150.4.1 - 192.150.5.254 192.150.5.255
All 64 of the Possible /22 Networks for 192.150.*.*
192.150.0.0 192.150.0.1 - 192.150.3.254 192.150.3.255
192.150.4.0 192.150.4.1 - 192.150.7.254 192.150.7.255
So you only have option i can see if you looking 192.150.3.X and 4.X network required in same pool use /21
All 32 of the Possible /21 Networks for 192.150.*.*
192.150.0.0 192.150.0.1 - 192.150.7.254 192.150.7.255
BB
It would likely be better if you ask this question over at the Network part of the community as it is not related to anything within Collaboration.
Response Signature
