02-26-2006 09:19 PM - edited 03-03-2019 11:52 AM
Hi...
I was wondering whether it is possible to connect more than one leased line to a single serial interface using logical interfaces like it is done with frame relay or ATM?
Or one has to have a separate modem and serial interface/router for each leased line?
Any feedback is highly appreciated
02-26-2006 09:39 PM
You need to have seprate modem and serial interface for each leased lines.
regards,
02-27-2006 06:46 AM
The only thing that comes to mind is using a channelized interface where you can configure multiple logical serial interfaces and allocate your timeslots as you wish.
Have a look at the attached link if channelized i/f configuration is what you are after.
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008045523c.html
E.
