Low Internet Upload speed
NInja Black
We are receiving low internet upload speed (6-8Mps) at our office location. The download speed is good (50Mbps).
Got in contact with the ISP Comcast and tried testing it bypassing our internal n/w i.e. connecting my laptop directly to Cienna (Comcast GW)
and both speeds were around 50Mbps.
Testing the same through my router the speed goes down. Just the Upload speed.
Could there be a configuration in our router thats causing this? Moreover we have few other offices near by with the similar router config but they seem to be getting good speeds.
FYI on the internet interface thee settings are
'duplex full
speed auto'
Any insight will be highly appreciated. Thanks
2 Accepted Solutions
As Leo noted above,
(ROUTER)#sh run int g0/2
interface GigabitEthernet0/2
description FW_Link
ip address 10.xx.xx.xx xx.xx.xx.xx
ip access-group 120 in
ip nat inside
ip nat enable
ip virtual-reassembly in
duplex full <----
speed 100 <----
end
These are manually set, the side going to the ASA, is it setup as auto/auto or manually configured?
So configuring the interface speed and duplex settings to auto/auto would resolve the issue?
Clear the counters and change the speed and duplex to auto/auto.
18 Replies 18
JohnTylerPearce
Level 7
Level 7
Sounds like from Comcast's perspective everything works as expected.
I'm assuming from the Cienna Comcast GW, it's connected to the Router, and then to your local lan.
Have you tried a new cable going from the router to the cable modem, also what router do you have?
It's also possible that someone is hogging your upload bandwidth, and when you run a test, that's all your
seeing is 6 to 8Mbps.
John,
Yes the Cienna is connectd to router. router to FW n lan.
The cable between Cienna and router is pretty new. Will still try swapping it after office hours.
Router - Cisco 3925
FW - ASA 5515
Is there a way to find out if someone is using up the bandwidth.
Thanks for your help.
On your router, the port going to the cable modem and the port going to the ASA, can you post a 'show int x/x' for each port?
After you do that, clear the statistics for that interface.
Please find below the run config for the 2 interfaces. For int g0/1, speed was 100. Changed it to 'auto' last night.
The ACL 199 and 120 are to allow/stop telnet access.
(ROUTER)#
(ROUTER)#sh run int g0/1
Current configuration : 219 bytes
interface GigabitEthernet0/1
description Cienna_EDI_Link
ip address 50.xx.xx.xx 255.255.255.252
ip access-group 199 in
ip nat outside
ip nat enable
duplex full
speed auto
ipv6 enable
end
description FW_Link
ip nat inside
ip nat enable
duplex full
speed 100
end
Ninja,
Sorry for the delay, I've been pretty busy at work today. I see you ran the 'show run int gi0/1 and gi0/2' command, can you run the 'show int gi0/1 andshow int gi0/2' and paste that config, excluding any private information?
Been checking for your reply whole day.
Thanks for spending time on it out of your busy schedule.
(ROUTER)#sh int g0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is PQ3_TSEC, address is XXXXXXXX
  Description: EDI_Link
  Internet address is 50.XX.XX.XX/XX
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1561000 bits/sec, 227 packets/sec
  5 minute output rate 300000 bits/sec, 166 packets/sec
     15458530 packets input, 15054104366 bytes, 0 no buffer
     Received 59 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     9857268 packets output, 2393627370 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     1 lost carrier, 0 no carrier, 17724 pause output
(ROUTER)#
(ROUTER)#sh int g0/2
GigabitEthernet0/2 is up, line protocol is up
  Hardware is PQ3_TSEC, address is XXXXXXXXXXXX
  Description: FW_Link
  Internet address is 10.XX.XX.XX/XX
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 5/255, rxload 1/255
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 466
  5 minute input rate 543000 bits/sec, 351 packets/sec
  5 minute output rate 2177000 bits/sec, 475 packets/sec
     14968797 packets input, 3762142601 bytes, 0 no buffer
     Received 4160 broadcasts (0 IP multicasts)
     39311 runts, 5 giants, 0 throttles
     191160 input errors, 191157 CRC, 5 frame, 3 overrun, 0 ignored
     0 watchdog, 3699 multicast, 0 pause input
     21324023 packets output, 18667280563 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     2407 unknown protocol drops
     12 lost carrier, 0 no carrier, 0 pause output
(ROUTER)#
Nuts.  Those CRC are pretty high.
Sounds like you've got a bad cable.
This could be what's causing the CRC errors.  Is the port's speed and duplex setting hard-coded?
As Leo noted above,
description FW_Link
ip nat inside
ip nat enable
duplex full <----
speed 100 <----
end
The cable is new. Will still replace it.
I manually configured the speed(100) and duplex(full) settings on the interface.
On the ASA they are set to auto/auto. Didnt touch that.
Resolved.
Till before I was making changes at the EDI link and not the FW link thinking it was the issue between the Cienna and my router connection.
Thanks to John and Leo for their time!!!
Thanks for taking the time to rate our posts.
Hi i am facing same problem with slow uploading speed but download is ok on switch...?
