Low Internet Upload speed
NInja Black
We are receiving low internet upload speed (6-8Mps) at our office location. The download speed is good (50Mbps).
Got in contact with the ISP Comcast and tried testing it bypassing our internal n/w i.e. connecting my laptop directly to Cienna (Comcast GW)
and both speeds were around 50Mbps.
Testing the same through my router the speed goes down. Just the Upload speed.
Could there be a configuration in our router thats causing this? Moreover we have few other offices near by with the similar router config but they seem to be getting good speeds.
FYI on the internet interface thee settings are
'duplex full
speed auto'
Any insight will be highly appreciated. Thanks
18 Replies 18
what switch platform do you have, and how are you connected to the Internet ? Post the configs of both your switch and your router...
 i am using 3650 L3 switch configured as a stack.
this is interface configuration connected to firewall:==
GigabitEthernet2/0/24 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is f44e.0567.4c98 (bia f44e.0567.4c98)
Description: "FIREWALL 2"
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 3/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Last clearing of "show interface" counters 06:43:42
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 14442000 bits/sec, 2208 packets/sec
5 minute output rate 3784000 bits/sec, 1669 packets/sec
75292138 packets input, 68207971809 bytes, 0 no buffer
Received 186581 broadcasts (185972 multicasts)
0 watchdog, 185972 multicast, 0 pause input
52509583 packets output, 14759511924 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
uploading speed issue ???
this interface is connected to active firewall.
Laptop-->L2 switch--> L3switch-->checkpoint fw-->internet.
i connect my laptop to L3 switch still facing upload speed issue.
on single laptop also.
