11-12-2019
12:38 AM
- last edited on
01-09-2024
12:03 AM
by
Translator
Hi All,
With the 89x routers going end of sale I am trying to setup my 1st ISR-C1113 router using 4G LTE to for internet connectivity. I can only get the cellular interface to to apply for an IP address if I ping 8.8.8.8. Until then the cellular profile remains inactive.
Here are my settings:
interface Cellular0/2/0
ip address negotiated
ip nat outside
dialer in-band
dialer idle-timeout 0
dialer-group 1
pulse-time 1
controller Cellular 0/2/0
lte sim data-profile 1 attach-profile 1 slot 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
I have set the APN with the following command:
cellular 0/2/0 lte profile create 1 wap.my-isp.co.uk
After powering up and waiting for the router to recognise the SIM it won't bring the profile into an active state. "show cellular 0/2/0 all" gives the following result:
Solved! Go to Solution.
11-15-2019 02:32 AM
Under "Restrictions for Configuring Cisco 4G LTE Advanced" in the c1100 LTE documentation I found the following line:
"Currently, cellular networks support only user initiated bearer establishment"
I'm still waiting for a response from Cisco but this seems to confirm my suspicion.
This is a backward step over the 89x LTE routers for this model. VPN like DMVPN is a common way to connect to corporate networks and it means you can't use these routers for a quick deploy for offices that don't yet have wired connectivity, or who want to use LTE as a backup connection. This is a serious drawback, and with the 89x routers having reached EOS, it means there's no replacement.
11-15-2019
04:17 AM
- last edited on
01-09-2024
12:23 AM
by
Translator
I guess a workaround would be to configure a simple SLA that keeps the link up permanently:
ip sla 1
icmp-echo 8.8.8.8 source-interface Cellular0/2/0
ip sla schedule 1 life forever start-time now
11-18-2019 08:08 AM
sla looks promising as a workaround. I'll give that a go tomorrow when I have access to the router again.
11-18-2019 08:11 AM
Sure, let us know how that goes.
11-19-2019
01:52 AM
- last edited on
01-09-2024
12:22 AM
by
Translator
I found a solution!
The ip sla never worked and I don't know why.
I had the following config:
ip sla 1
frequency 5
Router#sh ip sla statistics
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: 08:39:23 UTC Tue Nov 19 2019
Latest operation return code: Timeout
Number of successes: 0
Number of failures: 14
Operation time to live: Forever
The ip sla won't bring up the interface but a ping from the CLI will. Don't ask me why!
I found the solution in the LTE deployment guide:
There is a section for DMVPN tunnels. There needs to be a watch list on the interface:
dialer watch-group 1
dialer watch-list 1 ip 8.8.8.8 0.0.0.0
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
The watch list works! It brings up the interface.
11-19-2019
02:05 AM
- last edited on
01-09-2024
12:20 AM
by
Translator
good one. Glad you found this to work...
Thinking about the IP SLA, the problem might be that the source interface is the cellular, and that is down, so maybe that cannot be the source. You might want to try this:
interface Loopback 100
ip address 100.100.100.100 255.255.255.255
ip sla 1
icmp-echo 8.8.8.8 source-interface Loopback 100
frequency 5
ip route 8.8.8.8 255.255.255.255 Cellular0/2/0
08-09-2022 07:22 AM
The Watch List Worked for me also. It brings up the Cellular interface!!!
Thank you Ron for this solution
