mac-access-list
hii,
we are using 3845 router in our WAN network.and each router (LAN) interface we are creat 3 to 4 subinterface. i want to block one of the Mac-address in the router,how it could be done ? through Mac-access-list i am creat Mac access ist but in LAN interface there is no command to allow mac access list??..how it's possible??
paolo bevilacqua
Please explain what problem are you trying to solve, mac ACL are for bridging only.
hii ,
just i want to deny Mac id in my router (3845) how it's possible???
Bobby Thekkekandam
In order to do this you will have to enable bridging on the interface to apply the access-list on. See the example below:
Example:
access-list 700 permit <48-bit hardware SOURCE address> <48-bit hardware
DESTINATION address>
access-list 700 deny
access-list 700 permit 0.0.0 0.0.0 <--- Permit all
interface Ethernet0
ip access-group 700 in <--- applied inbound
Here is a sample config of what you need in the router in order to filter a mac address.
NOTE: In order to use MAC access-lists in a router you need to configure bridging. In this
case is IRB.
config t
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
int e0 (or the interface you need)
no ip address
bridge-group 1
bridge-group 1 {input-address-list 700 | output-address-list 700} exit
int bvi1
ip address
exit
access-list 700 deny 0000.0000.0000
access-list 700 permit 0000.0000.0000 ffff.ffff.ffff
Depending on what else you're doing on the interface, this may or may not be a valid solution.
