Management Access through VRF
Kryptkeeper
     I have been reading some articles, and blogs, about accessing the VTY lines when the traffic is coming from an interface that is apart of a VRF. According to what I have read, you should not be able connected to the VTY line unless you put an access-list on the VTY lines with the "vrf-also" keyword. Also, the articles were referring to using 4500s, or lower end switches.
     I am coming up with a design and wanted to implement VRF-lite. When I was mocking up the design I noticed I could connect to the VTY lines of a device eventhough the L3 interface I was telnet'd to was in a VRF. I was using three 3725s to see if this actually worked, or not.
     I was hoping that in the end traffic within this VRF would not be able to connect to the management plane. Also, does the inability to connect to the VTY lines a platform/IOS specific issues? Any insight would be appreciated. Thanks.
burak-isiksoy
Why dont you use VTY access-list.
Marwan ALshawi
access to the device through a certain VRF dose not mean you can not mange the device
the VRF is just virtulising the control plane/routing of the router once you in through telnet or ssh for example you can manage that router but the benefit of having differnt vrf for managment is to have a separate routing and management interface of the actual global routing table and other interfaces
this is by default in the ASR and Nexus which they have a dedicated management interface in management VRF
Nicholas Poole
Although other replies below suggested this wasn't the case, I found what you had read to be true.
On a C3750 switch I had a vty acl, I then added a VRF and wanted to get to the cli via that VRF, but I couldn't, I always got connection refused.  When I added "vrf-also" keyword to the access-class command on the vty line I could now gain access.
I've got the same experience with a 2921 router running 15.2(4) IOS.
Best regards,
Milan
