Enabling DHCP Server on a router
haji_akhundov
Hi everyone!
I have 4 subinterfaces on FastEthernet 0/0, listed below.
How can I make such that each of them has a DHCP server enabled?
interface FastEthernet0/0.4
description VLAN20-Management
encapsulation dot1Q 20
ip address 10.0.0.1 255.255.255.0           < -- DHCP for this one
interface FastEthernet0/0.5
description VLAN40-VoIP
encapsulation dot1Q 40
ip address 10.0.1.1 255.255.255.0           < -- DHCP for this one
interface FastEthernet0/0.6
description VLAN60-VIP_Users
encapsulation dot1Q 60
ip address 10.0.2.1 255.255.255.0            < -- DHCP for this one
interface FastEthernet0/0.7
description VLAN80-Hosts
encapsulation dot1Q 80
ip address 10.0.3.1 255.255.255.0            < -- DHCP for this one
Thanks! Hope to get some good advice!
AhmedSonba
Hello Haji,
You can do it for example like the following :
ip dhcp excluded-address 10.0.3.1
ip dhcp excluded-address 10.0.2.1
ip dhcp excluded-address 10.0.1.1
ip dhcp excluded-address 10.0.0.1
ip dhcp pool Management
network  10.0.0.1 /24
domain-name Management .com
default-router  10.0.0.1
ip dhcp pool VOIP
Network 10.0.1.1 /24
domain-name VOIP.com
default-router  10.0.1.1
ip dhcp pool VIP
network 10.0.2.1/24
domain-name Vip.com
default-router  10.0.2.1
ip dhcp pool Hosts
network  10.0.3.1/24
domain-name hosts.com
default-router  10.0.3.1
Hope it will help
Ahmed Sonba
8 Replies 8
cadet alain
the dhcp service is listening on every interface but you need to configure a pool for each subnet you want to lease out addresses.
Regards.
Alain
Dear alain,
Thanks for the reply.
I tried what Ahmed suggested and what you actually suggested also. I still have a theoretical question in mind:
How does the router know which pool to use on which interface?
p.mcgowan
Level 3
Level 3
you can create a separate dhcp pool for each of the subnets you require.
the following doc shows a good example
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t1/feature/guide/Easyip2.html#wp25541
please rate helpful posts
That's a nice document there. Thanks for sharing. =)
AhmedSonba
Hello Haji,
ip dhcp pool VOIP
ip dhcp pool VIP
network 10.0.2.1/24
domain-name Vip.com
ip dhcp pool Hosts
network  10.0.3.1/24
Hope it will help
Ahmed Sonba
Thank you Ahmed.
This did help actually. I tried it on packet tracer and it works fine. But I'm still wondering how does the router know which pool to use on which interface, have any clue?
Hi Haji,
As mentioned by Alain, the router will listening the DHCP request from each of these interface, let say if one request if heard from FastEthernet0/0.5, router will accordingly allocate ip address based the interface ip, in this case, 10.0.1.0/24.
Hope this helps.
okay. it makes sense. thanks. =)
