Many to One NAT
michael.zammit
Hi Guys,
I have a requirement where I need to NAT the destination IP address of traffic that is from two different sources.
For example, If either 172.31.50.1 or 172.31.50.2 send traffic to the destination 172.31.164.48, I require the destination IP to be NAT'd to 172.16.4.1.
What's the best way of going about this?  I've tried several different NAT setup's but recieve a Cisco error message that the IP address I'm trying to NAT to is already mapped to another IP.
Any help would be greatly appreciated.
Thanks.
blau grana
Level 7
Level 7
Hello Michael,
Maybe I missed something, but to me it seems that you just need simple static NAT.
ip nat inside source static 172.16.4.1 172.31.164.48
172.31.50.0/24 ---- network ---- router ---- 172.16.4.0/24
router config
int fa0/0
  descript interface toward network
  ip add 172.31.164.48 255.255.255.0
  ip nat outside
int fa0/1
  descript interface subnet 172.16.4.0/24
  ip add 172.16.4.254 255.255.255.0
  ip nat inside
All traffic which arrive on interface (172.34.164.48) will be forwarded to IP 172.16.4.1 [destination IP will be translated]
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Dennis Mink
What device is this on? ASA? Router?
what you require is destination NAT.  If its a router, check this link out
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f8e.shtml
Please remember to rate useful posts, by clicking on the stars below.
Thanks for your reply.
Yep, it is for a router.
I've had a look at the above link but am I little unsure of it.  WIll it allow me to specifically set multiple destination IP's to nat to the same address?  How would this be configured?
blau grana
Level 7
Level 7
Hello Michael,
router config
int fa0/0
  ip nat outside
int fa0/1
  ip nat inside
Best Regards
