Mapping MAC and IP address
intertouch
Hi, I am using the Cisco 3825 router as the DHCP server. How should I configure the router to ensure certain MAC addresses of the PCs always get the same ip address via DHCP?
ankurbhasin
Level 9
Level 9
Hi Friend,
You can got for static DHCP binding while configuring your router as DHCP server but remember you have to configure seperate DHCP pools for each single host for static binding.
service dhcp
ip dhcp pool host1
host 192.168.1.2 255.255.255.0
client-identifier xxxx.xxxx.xxxx ! put your MAC address here
default-router 192.168.1.1
You will need to configure one DHCP pool per client.
Specify the MAC address of each host and the associated IP within each pool...
This link will give you all details about DHCP related commands
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipras_r/1rfdhcp.htm#1018170
HTH, if yes please rate the post.
Ankur
ikizoo4
You can use "manual binding", but keep in mind that
only configure one manual binding per host pool,, lot of work to do.
ip dhcp pool Mars
host ip addess
hardware-address MAC type
