MARKING A TRAFFIC WITH AF31
dawitassefa
Hello ,
    I have a Cisco 3725 router with IOS version "Cisco IOS Software, 3700 Software (C3725-ADVIPSERVICESK9-M), Version 12.4(12)". And this router is serving as a CE route for our MPLS connection to the service Provider. We do also have multiple VRFs ( around 10) and the WAN interface is DS3. So we created point-to-point subinterfaces and we put them in different vrfs. We have now transitioned to a new ISP and the ISP requested us to mark all of our outgoing traffics with DSCP AF31. So I have created the following policy-map
policy-map TRAFFIC-OUT-WAN-AF31
class TRAFFIC-OUT-WAN
  set ip dscp af31
class-map match-any TRAFFIC-OUT-WAN
match any
Now we do have multiple GRE tunnel interfaces sourced from one of the WAN subinterface ( which is a member of VRF A). So the moment I applied the the policy-map  on this WAN sub-interface (using the syntax "service-policy out TRAFFIC-OUT-WAN-AF31"), most of the GRE tunnels went down. And there is eBGP running on top of these GRE tunnels. Any idea please?
5 Replies 5
dgroscost
Level 4
Level 4
Have you tried applying the service policy to the physical interface?
try different labeling
  set ip dscp af31                                                              -------- here try another  labeling
match any
Ask your provider how they are transmiting/dropping packets of different labeling
  dgroscost:  Yes I have tried to apply the policy-map on the physical interface. It will just bring down some of the GRE tunnel interfaces.
What do you mean by different labeling? Can you please further elaborate your idea with an example?
I thank you guys for all of your support
cflory
Did your CPU spike at all when you enabled the service policy statement?  I've seen this in the past before as a bug, but perhaps not in this instance.
I did NOT checked that though! But I belive it might be a bug as the IOS is a bit old . The funny part is that some of the GRE tunnels are up and the BGP established on top of these GRE tunnels. But majority of the tunnels are down. I might have to open a ticket with CIsco...I will advice you my findings.
