match vlan is not supported for this interface
rhamietron
I have a 10Mbps connection link which I will like to reduce to 5Mbps on a 6509 switch as indicated in the config below.
class-map match-all vlan313
match vlan 313
policy-map traffic-policy
     class vlan313
          shape average 5000000 20000 20000
interface Vlan 313
     service-policy input/output traffic policy
After applying the service policy on the vlan interface, i got this
"match vlan is not supported for this interface"
Any idea will be appreciated and if there are other means to achieve this, please do let me know.
I actually tried the rate limit command but I cant see the effect using the speedtest.
cadet alain
a VLAN= 1 subnet so you can use an ACL matching permitting the subnet and then match on this ACL.
Alain
cadet alain
Alain
Hi Cadet,
Thanks, been quite busy, the ACL grouping solved the issue.
Thanks.
