Matching prefixes using route maps
limtohsoon
Hi Sir,
I want to match the prefix address 172.18.252.4/30 using a route map. I understand it can be done by either the following configs:
route-map TESTMAP permit 10
match ip address TESTACL
ip access-list extended TESTACL
permit ip 172.18.252.4 0.0.0.3 any
OR
permit ip host 172.18.252.4 host 255.255.255.252
Kindly advise which way is preferred and any advantage of one method over the other?
Thank you.
B.Rgds,
Lim TS
CSCO10892433
Level 4
Level 4
Hi,lomtohsoon
The first route-map will permits the following prefix:
172.18.252.4/30
172.18.252.4/31
172.18.252.6/31
172.18.252.4/32
172.18.252.5/32
172.18.252.6/32
172.18.252.7/32
because they all fall within the same range 172.18.252.4~172.18.252.7
The second route-map will only permit the prefix 172.18.252.4/30
Hope this help
SSLIN
