Maximum E1 Cards supported on 2811
hardiklodhia
Hello All,
Wanted to confirm maximum E1 ports supported on 2811 without any performance degradation.
2811 has 4 HWIC slots, i need 8 E1 ports to be connected to different sites.if i populate all 4 slots with VWIC2-2MFT-G703 which makes 8 E1 ports, Any performance issues??
Thanks in advance.
Giuseppe Larosa
Hello Hardik,
C2811 is accredited of 120000 pps
ISR 2811 3,000 1.536 120,000 61.44 No
so from the performance point of view it shouldn't be a problem
see file in attachment
the 4 slots can be used as you would like:
>> 4 slots, each slot can support HWIC, WIC, VIC, or VWIC type modules
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html
So it should work
depending on WAN provider prices in your region you may want to consider the use of a single NM E3 subrate instead of paying for 8 E1 links
Hope to help
Giuseppe
Thank you very much Giuseppe.
E3 is not available from ISP.
paolo bevilacqua
Hi, you should use instead:
NM-8CE1T1-PRIor 2x HWIC-4T1/E1
Also in most cases the regular VWIC is OK, do not need the G703 version.
