SPA-1XCHSTM1/OC3, configuring 64kbps channels ? Is it possible ?
dumlutimuralp
Hi all,
Is it possible to configure 64kbps channels on the SPA-1XCHSTM1/OC3 card on an 7613 with the kitlist mentioned below ?
Product
Description
Quantity
7600-SIP-200=
Cisco 7600 Series SPA Interface Processor-200
MEM-SIP-200-512M
512MB Memory for 7600 SIP-200
SPA-1XCHSTM1/OC3
1-port Channelized STM-1/OC-3c to DS0 Shared Port Adapter
SFP-OC3-IR1
OC3/STM1 SFP, Single-mode fiber, Intermediate Reach
Included: 7600-SPA
SPA for Cisco 7600; No Physical Part; For Tracking Only
Thanks in advance.
Dumlu
Giuseppe Larosa
Hello Dumlu,
yes you should be able to configure the channelized OC-3 with a level of detail of DS0 channel-group on an E1/T1.
( ech group made of one or more DS0 timeslots)
Be aware that:
the OC-3 will be carrying three DS3/E3 channelized on the port.
On their turn each channelized DS3/E3 can be configured as a group of T1/E1 ports.
Each E1/T1 can be then configured as a controller with one or more channel-groups.
The ability of using sub E1/T1 depends also on the capabilities of external RED /ADM connecting to the OC-3 port.
see
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76cfstm1.html#wp1161296
However, you can expect that there will be a limit on the max number of channel-groups you can configure on it.
Hope to help
Giuseppe
