MEC distance limits?
CSCO10235163
Hi all,
I would connect a VSS system with 2 upstream device which are remotely located (15 km and 600km).
The idea is to build 2 MECs (from the VSS to each site) and to configure 1 p2p on each MEC.
The links forming the MEC don't necessarily follow the same physical path.
The doubt is: does exist any limitation on maximum distance for MEC?
I suppose the alternative should be activating a p2p for each link, OSPF and ECMP..
0 Replies 0
