Merging 2 Separate Networks on 1 Cisco Router, different subnets
NateJewett0517
Hello -
I have a branch location that exists on a 192.168 subnet that will be physically moving into our main location that is on a 10.10 subnet. I am hoping that I can use the Cisco 2951 Router at the main site to handle both networks, but do not have much experience doing that. The services rendered by this branch site requires it to remain on the 192.168 subnet for the time being. Is there a way to run both subnets off 1 router and 1 curcuit? Or, is it a requirement to bring the existing circuit from the branch site into the picture and have it hooked up via that?
My first post in the Cisco Community Forums, so thank you in advanced for any insight.
Hello
Basically you'll need to do something similar to below.
Main Site router
1) create a sub-interface for the branch users and assign them a vlan and advertise this subnet into eigrp
int gig0/0.10
description branch_site_users_vlan 10
encapsulation dot1q 10
ip address 192.168.171. 255.255.255.0
ex
router eigrp 100
no auto-summary
network 192.168.171.1 0.0.0.0
2) create a dhcp pool as per branch site
ip dhcp excluded-address 192.168.171.0 192.168.171.69
ip dhcp pool nchs
network 192.168.171.0 255.255.255.0
default-router 192.168.171.1
dns-server 10.0.0.5 10.0.0.6 10.1.0.5
Lease 0 8
Firewall
Add a static route pointing back to the main router for new subnet ( note not applicable if eigrp is running between the fw and the main branch router)
route Inside 192.168.171.0 255.255.255.0 10.x.x.x
Add the new subnet to exiting NAT rules
object network LAN
subnet 10.10.1.0 255.255.255.0
subnet 192.168.171.0 255.255.255.0
nat (Inside,Outside) after-auto source dynamic LAN interface
Switch
On the switchport connecting to main site router , change this into a a trunk port so to allow communication for the now two subnets and create L2 vlan for the new vlan users.
int x/x
description link to main site router
switcphort mode trunk
exit
vlan 10
name branch users
exit
Kind Regards
Paul
8 Replies 8
balaji.bandi
You can run both subnet in same router with 1 ISP link or 2 ISP Links ( depends on the link speed and utilisation of users)
on the extiing router add the new IP range and add them to NAT pool so user can get internet and can also access local 10.X  range vice versa.
here is the example to setup one :
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13772-12.html
BB
Dennis Mink
Yes the 2951's can do intervlan routing, so you can route between the two internal subnets.
send current config so we can append
I am assuming you have 1 internet link or WAN link that will serve both?  like Balji said that should be a matter of expanding NAT statements to include new subnets, but again send curent
Please remember to rate useful posts, by clicking on the stars below.
Thank you both for the reply, definitely sending me in the right direction on this. Yes, I am hoping that 1 WAN link can service both of the subnets. Currently, the sites are running off their own routers and links, so I will send along the configs for both.
Branch Location:
hostname WIC-Encinitas
boot-start-marker
boot-end-marker
aaa session-id common
memory-size iomem 15
clock timezone PST -8
clock summer-time PDT recurring
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp pool nchs
dns-server 10.0.0.3 10.0.0.4
lease 15
ip name-server 10.0.0.3
ip name-server 10.0.0.4
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
description LAN Connection
ip address 192.168.171.1 255.255.255.0
speed 100
full-duplex
interface FastEthernet0/1
description Cox MPLS
ip address 192.168.168.171 255.255.255.0
speed 100
full-duplex
router eigrp 100
network 10.0.0.0
network 192.168.1.0
network 192.168.168.0
auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.168.254
ip http server
no ip http secure-server
logging 10.0.0.4
snmp-server community public RO
snmp-server community nchspriv RW 10
snmp-server community nchspub RO 11
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server host 10.0.0.83 pubnchs
control-plane
bridge 1 protocol ieee
line con 0
line aux 0
line vty 0 4
transport input telnet
scheduler allocate 20000 1000
ntp clock-period 17207936
ntp server 10.0.0.3
end
Main Site:
version 15.7
hostname NCHS-ENCINITAS
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$oJnT$SNlhTUQWgoEYcdnlydmsR.
enable password 7 091D400A160B03000400
aaa new-model
aaa authentication login default local-case
clock timezone PST -8 0
ip dhcp excluded-address 10.10.1.0 10.10.1.69
ip dhcp pool nchs
network 10.10.1.0 255.255.255.0
default-router 10.10.1.1
option 176 ascii "MCIPADD=192.168.85.31,10.3.1.31,MCPORT=1719,L2QAUD=6,TFTPSRVR=10.0.0.203,HTTPSRVR=10.0.0.203"
option 242 ascii "MCIPADD=192.168.85.31,10.3.1.31,MCPORT=1719,L2QAUD=6,TFTPSRVR=10.0.0.203,HTTPSRVR=10.0.0.203"
lease 15
ip dhcp pool nchs_acg
host 10.10.1.143 255.255.255.0
hardware-address 01b8.27eb.4fdd.4e
client-name ACG-Encinitas
ip domain name nchs-health.org
ip name-server 10.0.0.5
ip name-server 10.0.0.6
ip name-server 10.1.0.5
ip cef
no ipv6 cef
license udi pid CISCO2951/K9 sn FTX1703AM74
redundancy
class-map match-any VoIP
match ip dscp ef
match ip dscp af41
match access-group 100
policy-map voipQoS
class VoIP
priority 768
class class-default
fair-queue
random-detect dscp-based
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.10.1.1 255.255.255.0
ip flow ingress
ip flow egress
ip policy route-map SDWAN
duplex full
speed 1000
interface GigabitEthernet0/1
ip address 192.168.1.10 255.255.255.0
ip flow egress
duplex full
speed 100
service-policy output voipQoS
interface GigabitEthernet0/2
description SD-WAN
ip address 10.10.2.1 255.255.255.128
duplex auto
speed auto
router eigrp 100
network 10.0.0.0
network 192.168.1.0
ip local policy route-map localtraffic
no ip http server
ip flow-export version 5
ip flow-export destination 10.0.0.94 2055
ip route 0.0.0.0 0.0.0.0 10.0.0.207
ip route 54.193.207.248 255.255.255.255 10.0.0.207
ip route 64.34.22.218 255.255.255.255 10.0.0.207
ip route 64.34.22.221 255.255.255.255 10.0.0.207
ip route 64.34.22.222 255.255.255.255 10.0.0.207
ip route 64.34.22.223 255.255.255.255 10.0.0.207
ip route 64.62.142.2 255.255.255.255 10.0.0.207
ip route 64.62.142.12 255.255.255.255 10.0.0.207
ip route 104.154.25.115 255.255.255.255 10.0.0.207
ip route 108.161.147.0 255.255.255.255 10.0.0.207
ip route 170.146.39.22 255.255.255.255 10.0.0.207
ip route 170.146.39.167 255.255.255.255 10.0.0.207
ip route 170.146.96.22 255.255.255.255 10.0.0.207
ip route 199.231.78.0 255.255.255.255 10.0.0.207
ip route 207.254.3.240 255.255.255.255 10.0.0.207
ip route 209.134.58.52 255.255.255.255 10.0.0.207
ip access-list extended SDWAN
permit ip any 10.80.11.0 0.0.0.255
permit ip any 10.0.0.0 0.0.255.255
permit ip any 10.100.0.0 0.0.0.255
permit ip any 10.100.1.0 0.0.0.255
permit ip any 192.168.85.0 0.0.0.255
permit ip any 10.10.1.0 0.0.0.255
logging host 10.0.0.4
ipv6 ioam timestamp
route-map localtraffic permit 10
match ip address SDWAN
set ip next-hop 10.10.2.2
route-map SDWAN permit 10
snmp-server community nchspub RO 10
snmp-server host 10.0.0.94 pubnchs
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
ntp server 10.0.0.3
end
On high level your NAT taking place in different device. ? what is the device 10.0.0.207 you point as GW.
BB
Yes the NAT policies currently exist on our Firewall, which is the 10.0.0.207
Then you should have your 192 or new IP range need to route to FW and make NAT configuration and ACL in the FW (by the what FW, ASA or any other vendor?
BB
Hello
Main Site router
int gig0/0.10
ex
router eigrp 100
no auto-summary
ip dhcp pool nchs
Lease 0 8
Firewall
object network LAN
Switch
int x/x
exit
vlan 10
name branch users
exit
Kind Regards
Paul
This is all super helpful information, I will give it a shot
