When issuing the write command on Cisco 2950 switch i receive the following message:
% Warning: Saving this config to nvram may corrupt any network management or security files stored at the end of nvram. Continue? [no]:
% Configuration buffer full, can't add command:tacacs-server host {ip address} %Aborting Save. Compress the config.[OK]
I haven't selected yes on the above as unsure of the cnsequences.
The Cisco 2950 switch is running with version:
flash:c2950-i6q412_mz.121-19.Ea1a.bin
Version 12.1(19)EA1a
Martin
