Metro Ethernet on Cisco 7206 VxR
network_a
Hi All,
We are planning to terminate a 4 mbps metro ethernet link on a Cisco 7206 router. Can anyone help me if there is any special config required on the port to bring the link up at both ends.
Much appreciate the help.
hoogen_82
Level 4
Level 4
You don't have to worry about anything. Just go about configuring your ethernet interfaces as usual. I guess they are providing you with an ethernet end.
Hoogen
Hi Hoogen
Thanks very much.Just a small concern, do we have to keep the ports in auto negotiate or 100 Mbps full duplex. Which one do you think would be more suitable.
Rgds.
Hoogen is right.
Regarding speed and duplexing, it is required for MetroEthernet to configure customer end devices to Full-Duplex/100BaseT.
