missing peer-policy option
i_hanu
Hi!
I have an issue, how can I apply template rr-policy to a neighbor session? I don't have any option
P0#show version
Cisco IOS Software, IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.6(2)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 22-Mar-16 16:19 by prod_rel_team
ROM: Bootstrap program is IOSv
P0 uptime is 25 minutes
System returned to ROM by reload
System image file is "flash0:/vios-adventerprisek9-m"
Last reload reason: Unknown reason
P0(config)#router bgp 65500
P0(config-router)#neighbor 1.1.1.1 inherit ?
peer-session Inherit a peer-session template
P0(config-router)#neighbor 1.1.1.1 pe
P0(config-router)#neighbor 1.1.1.1 peer-group ?
WORD peer-group name
P0(config-router)#neighbor 1.1.1.1 peer-?
peer-group
Configuration:
router bgp 65500
template peer-policy rr-policy
route-reflector-client
exit-peer-policy
template peer-session rr
remote-as 65500
update-source Loopback1
exit-peer-session
bgp log-neighbor-changes
neighbor 1.1.1.1 inherit peer-session rr
neighbor 2.2.2.2 inherit peer-session rr
neighbor 3.3.3.3 inherit peer-session rr
neighbor 4.4.4.4 inherit peer-session rr
address-family ipv4
neighbor 1.1.1.1 activate
neighbor 2.2.2.2 activate
neighbor 3.3.3.3 activate
neighbor 4.4.4.4 activate
exit-address-family
address-family vpnv4
neighbor 1.1.1.1 send-community extended
exit-address-family
Sorry can you more elaborate.
MHM
