Missing RIP Routes
feroz syed
Level 3
Level 3
Routes are visible on PE routers but on client side no rip routes showing. PE and Client connected with RIP protocol. Attached topology screenshot. Below show cmds and configs available.
R6#sh run | sec router rip
router rip
version 2
no auto-summary
address-family ipv4 vrf RIP
redistribute bgp 65000
network 10.0.0.0
no auto-summary
exit-address-family
R6#sh runn
Building configuration...
Current configuration : 1974 bytes
! Last configuration change at 15:07:18 UTC Mon Feb 3 2020
version 15.2
hostname R6
boot-start-marker
boot-end-marker
vrf definition RIP
rd 100:100
route-target export 100:100
route-target import 100:100
address-family ipv4
exit-address-family
no aaa new-model
ip cef
no ipv6 cef
mpls label range 600 699
interface Loopback0
ip address 6.6.6.6 255.255.255.255
interface Loopback1
no ip address
interface FastEthernet0/0
ip address 10.4.6.6 255.255.255.0
ip ospf network point-to-point
ip ospf 1 area 0
speed auto
duplex auto
interface FastEthernet0/1
vrf forwarding RIP
ip address 10.2.6.6 255.255.255.0
speed auto
duplex auto
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router ospf 1
network 6.6.6.6 0.0.0.0 area 0
mpls ldp autoconfig
router rip
version 2
no auto-summary
network 10.0.0.0
no auto-summary
exit-address-family
router bgp 65000
bgp router-id 6.6.6.6
bgp log-neighbor-changes
neighbor 2.2.2.2 remote-as 65000
neighbor 2.2.2.2 update-source Loopback0
address-family ipv4
neighbor 2.2.2.2 activate
exit-address-family
address-family vpnv4
neighbor 2.2.2.2 send-community extended
exit-address-family
redistribute rip
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
mpls ldp router-id Loopback0
end
R6#
R6#sh ip route vrf RIP
Routing Table: RIP
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 1 subnets
B 1.1.1.1 [200/1] via 2.2.2.2, 00:16:39
10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
B 10.1.1.0/24 [200/1] via 2.2.2.2, 00:16:39
B 10.1.2.0/24 [200/0] via 2.2.2.2, 00:16:39
B 10.1.3.0/24 [200/1] via 2.2.2.2, 00:16:39
C 10.2.6.0/24 is directly connected, FastEthernet0/1
L 10.2.6.6/32 is directly connected, FastEthernet0/1
R 10.2.7.0/24 [120/1] via 10.2.6.2, 00:00:05, FastEthernet0/1
11.0.0.0/32 is subnetted, 1 subnets
B 11.11.11.11 [200/2] via 2.2.2.2, 00:16:39
172.16.0.0/32 is subnetted, 1 subnets
B 172.16.1.1 [200/2] via 2.2.2.2, 00:16:39
192.168.1.0/32 is subnetted, 1 subnets
B 192.168.1.1 [200/1] via 2.2.2.2, 00:16:39
R6#sh bgp vpnv4 uni all
BGP table version is 40, local router ID is 6.6.6.6
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 100:100 (default for vrf RIP)
*>i 1.1.1.1/32 2.2.2.2 1 100 0 ?
*>i 10.1.1.0/24 2.2.2.2 1 100 0 ?
*>i 10.1.2.0/24 2.2.2.2 0 100 0 ?
*>i 10.1.3.0/24 2.2.2.2 1 100 0 ?
*> 10.2.6.0/24 0.0.0.0 0 32768 ?
*> 10.2.7.0/24 10.2.6.2 1 32768 ?
*>i 11.11.11.11/32 2.2.2.2 2 100 0 ?
*>i 172.16.1.1/32 2.2.2.2 2 100 0 ?
*>i 192.168.1.1/32 2.2.2.2 1 100 0 ?
R6#sh bgp sum
BGP router identifier 6.6.6.6, local AS number 65000
BGP table version is 1, main routing table version 1
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
2.2.2.2 4 65000 70 65 1 0 0 00:52:36 0
CLIENT
SW-2#sh run | sec router rip
router rip
version 2
network 10.0.0.0
no auto-summary
SW-2#sh ip route rip
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
EMPTY*
Hello
You redistributing bgp intp rip without any metric, rip wont understand those bgp routes otherwise.
router rip
redistribute bgp 65000 metric 5
Also you could just advertise a default route ino the ce rtr rib table
router rip
default-information originate
Kind Regards
Paul
Hello
router rip
router rip
Kind Regards
Paul
it works !! but how could it happen because on R6 PE router we redistribute Rip route to Bgp , it affect on other side of the client or PE router. how this command "redistribute bgp 65000 metric 5" here we export the routes to BGP, but on PE which is R6 it already has Routes coming from R2-PE . if the redistribute cmd under bgp protocol means there is some logic, but here am totally confused. Thanks for your reply.
Hello
Route redistributed into bgp will be assigned with bgp attributes including weight and admin distance these ebgp routed are routed within the bgp vpn between the pe rtrs of R6-R2 however for those now bgp routes to be seen as valid rip routes in the vrf of the r1 then rip needs to understand these bgp routes in the form of a redistribution route with metric hence why you need to append a metric value that the rip protocol understands
Kind Regards
Paul
Thanks for your help. ☺
