Routing with firewalls
Senbonzakura
Hey everyone, I need your input.
So, I have a ASA5510 Firewall that has two Cisco ISR 1921 hooked into that firewall with HSRP for redundancy. The firewall is the edge router and the other two routers are hooked into two different switches which are in a hybrid mesh setup.
If I use another router like 1921 then lets say running OSPF as the edge router instead of the firewall everything works great.
How would I go about configuring the firewall as the edge router with routing tables and all, you can use your own IP address scheme. I got as far as configuring the interfaces with IP address and security levels. Also, in this situation since I only have two routers attached to two different switches running HSRP one router isn't even being used to route traffic. The main router, should it only run NAT or just statically configure the routes and leave it at that?
Thank you again.
if you use the firewall as a routing device, make sure you have:
same-security-traffic permit inter-interface
configured. That without knowing what the rest of your configuration looks like. Can you post the running config of the ASA ?
Hello
Can you post a diagram on your propose setup,
Also having the asa performing the L3 routing and inter-vlan routing any vlans on the fw if i remember won't by default.
To allow to communicate with each vlan - you need to allow intra/inter traffic and nat between the vlans.
Example:
int x/x
security-level 100
no shut
int x/x.100
nameif vlan100
security-level 100
vlan 1000
ip address 192.168.100.1 255.255.255.0
int x/x.200
nameif vlan200
security-level 100
vlan 200
ip address 192.168.200.1 255.255.255.0
same-security-permit intra-interface
same-security-permit inter-interface
static(vlan100,vlan200)192.168.100.0 192.168.100.0 netmask 255.255.255.0
static(vlan200,vlan100)192.168.200.0 192.168.200.0 netmask 255.255.255.0
Kind Regards
Paul
