MLP on atm interfaces
jeffbriones
Hi guys,
im still finding some documents here related to MLP on atm interfaces. Most of the documents i found are more on serial interfaces. Will this work.
thanks.
jeff
8 Replies 8
mounir.mohamed
Level 7
Level 7
Dear Jeff,
Kindly find the below MLP ATM configurations example, i hope that help you
interface Loopback13
ip address 13.13.13.1 255.255.255.252
interface Virtual-Template1
bandwidth 2048
ip unnumbered Loopback13
ppp multilink
ppp multilink fragment delay 14
ppp multilink interleave
interface ATM1/0.101 point-to-point
description MLPPP Test 1st Link
pvc 0/101
abr 2663 2663
encapsulation aal5autoppp Virtual-Template1
interface ATM1/0.102 point-to-point
description MLPPP Test 2nd Link
pvc 0/102
abr 2663 2663
Please rate helpful posts
Best Regards,
Mounir Mohamed
Hi Mounir,
would i still configure multilink interface on these one ? another thing is im using BGP on these will this affect my config ?
thanks.
jeff
Dear Jeef,
There are no problem problem to use BGP through all the links as soon as the links provided by the same provider and you are establishing the session via loopback ip address.
Jeef your case not clear please provide me with the senario that you would like to use to provide you with optimum configurations that can reach you needs.
PLease Rate helpful posts
Best Reagrds,
Mounir Mohamed
Hi Mounir,
Before we are using two isp to multihome. Now we had to remove one to cut cost and the other one told us to have a redundancy thru physical link. Its like having 2 fiber links with different geographical path. If one of the two fiber that would be damage, still we'll have connectivity. Here's the setup as per our isp.
1. Multilink via atm.
2. Single Local Router connected to their single router
3. 2 atm interfaces configured multilink for failover
atm1/0 ----fiber--- atm interface
R1 ---- --- ISP Router
at2/0 ----fiber--- atm interface
Here's basically the setup. Its for failover using MLP via atm.
Thanks.
jeff
Dear Jeff,
I hope to solve your problem this time :)
I got that you have one router with 2 ATM controllers and each controller facing provider router or even interface and and you gone bundle both ATM interfaces by MLPPP, and using BGP over the MLPPP interface Right? So you can use MLPPP via virtual-templete or via MLLP interface
Example 1 - (ATM Router) Virtual-temp interface
interface Loopback1
ip address 1.1.1.1 255.255.255.252
bandwidth ???
ppp multilink
interface atm1/0.1 point-to-point
description MLPPP 1st Link
pvc 1/1
abr 2663 2663
interface atm2/0.1 point-to-point
description MLPPP 2nd Link
pvc 2/1
abr 2663 2663
router bgp 65534
bgp router-id 1.1.1.1
neighbor 1.1.1.2 remote-as 109
neighbor 1.1.1.2 update-source loopback 1
Example 2 - MLPPP interface
Interface loopback1
interface Multilink1
no ip redirects
no ip unreachables
no ip proxy-arp
backup delay 2 60
ip tcp header-compression iphc-format
no cdp enable
ppp multilink
ppp multilink group 1
ppp multilink endpoint ip 1.1.1.2
max-reserved-bandwidth 100
interface atm1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
keepalive 2 2
no cdp enable
ppp multilink
interface atm2/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
keepalive 2 2
no cdp enable
ppp multilink
router bgp 65534
If its not clear pls let me know
Please Rate helpful posts
Best Reagrds,
Mounir Mohamed
Hi Mounir,
Thanks, lots of info i got from your config. I was thinkin why multilink and virtual template was provided by my isp. Here's the initial config, please comment on these. And kindly explain some of the commands involve, still finding some sites for these kind of setup.
ISP Side
interface Multilink X
bandwidth 10000
ip address x.x.x.x 255.255.255.252
ppp multilink
ppp multilink fragment-delay 10
multilink-group 1
interface ATM3/0
no ip address
no atm ilmi-keepalive
interface ATM3/0.1 point-to-point
description ***** 1st BACKHAUL *****
pvc PMSI 0/1
encapsulation aal5snap
protocol ppp Virtual-Template1
interface ATM4/0
no ip address
interface ATM4/0.1 point-to-point
description ***** 2nd Backhaul *****
pvc PMSI 0/2
protocol ppp Virtual-Template2
bandwidth 10000
no ip address
load-interval 30
ppp multilink
multilink-group 1
interface Virtual-Template2
bandwidth 10000
no ip address
load-interval 30
ppp multilink
multilink-group 1
MY SIDE
bandwidth 10000
ppp multilink
multilink-group 1
interface ATM4/0
no ip address
pvc PMSI 0/1
interface ATM6/0
no ip address
interface ATM6/0.1 point-to-point
pvc PMSI 0/2
bandwidth 10000
no ip address
load-interval 30
ppp multilink
multilink-group 1
bandwidth 10000
no ip address
load-interval 30
ppp multilink
multilink-group 1
thanks.
jeff
Dear Jeff,
Also the configuration you provide will achive your goal and i have no comments, SO go on and feel free to post more
Please Do not forget to mark the Conversation when your problem get solved.
Best Regards,
Mounir Mohamed
Hi Mounir,
I would like to ask if where should i implement my acl, is it on the atm interface or on the multilink interface ?
Thanks.
jeff
