mode enable don't work
akpeliodon
in ssh mode on a router I removed the enable secret mode and I saved afterwards I always try to connect in ssh mode and I receive an error message in the authentication but when I connect to this same router with a console cable I easily access privileged mode
how can I get back into enable mode during my ssh connection?
7 Replies 7
balaji.bandi
what router model ? and what IOS code running ?
what commands you removed ?
if the user is local and have priv 15 they can directly get in access as example below :
example i use below for all device to SSH v2 using local user cisco and cisco for lab :
enable secret 5 $1$jtK0$yyHFcVM7xyelts1csVwrV/
username cisco privilege 15 secret 5 $1$0qFD$ZEMDi.7z1QTtF4EuPdlSY.
aaa new-model
aaa authorization config-commands
aaa session-id common
clock timezone GMT 0 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
no ip domain-lookup
ip domain-name bb.com
ip cef
no ipv6 cef
ip ssh version 2
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous level 0 limit 20
stopbits 1
line aux 0
line vty 0 4
privilege level 15
password cisco
transport input ssh
transport output all
######### Generate SSH keys :
crypto key generate rsa
BB
CISCO 1941/k9 modele
transport input ssh
line vty 5 15
 login local
 transport input ssh
scheduler version 15.7
boot-start-marker
boot system flash:c1900-universalk9-mz.SPA.157-3.M5.bin
boot system flash:c1900-universalk9-mz.SPA.157-3.M9.bin
boot-end-marker
enable secret 5 $1$P9vN$mEFEcZiqJDgeQUX30von70
no aaa new-model
memory-size iomem 10
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1921/K9 sn FGL211723RS
line con 0
 password test123
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login local
allocate 20000 1000
that is the routeur configuration
I did not see the username in your config ? configure username and password and test it.
are you trying to login using Telnet or SSH ?
line vty 0 4
transport input ssh
BB
yes I just removed it from the publication for security reasons otherwise there are accounts created with enable mode privilege 15 and secret telnet does not work
To be able to login into the router directly in privileged mode, the following config must be applied:
username cisco privilege 15 secret cisco
line vty 0 4
 login local
 transport input ssh telnet
If you have aaa new-model configured, then add the following commands as well:
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
by the way when I connect with the console cable it does not ask me for username and password it takes me directly to privileged mode but when I try the remote ssh connection it gives me the username and password command prompt that I then validate when I do enable this is where I receive the error message error in the authentication
and i don't use aaa all username are created in router directely
This is probably because you didn't exit the console line from your previous login on the console.
If you dont have aaa new-model enabled, then the following commands:
line vty 0 4
 login local
should priviledged access to your device when you telnet or ssh to it.
Can you share the output of the command show run | include aaa ?
Regards, LG
