Module NM-E3 ATM
cassio.gomes
Hi All..
I have a router 2600 with the module NM-E3 ATM. This router is coneect withc cloud ATM. I can to configure this module to connect with WIC-1MFT-E1 with module AIM ? Or to configure this module with the bandiwdth 2MB E1..
Cassio Gomes
thomas.chen
Level 6
Level 6
How is the 2600 router connected to the ATM cloud. Is it a ATM link to the service provider or the connectivity is a 2mb Leased line to the service provider and then from there it is a ATM cloud. If the connectivity to the service provider is a Leased line then you can configure the port for 2Mb E1. If the link to the service provider is also ATM then configure the port for ATM.
