FTP Access - Help please.
wananga01
Community Member
recently we changed our ISP and have connected to them using a Cisco 1700 Router. The connection is working and all workstations can access the Internet. NAT is configured on the router and an ACL is applied to the inside interface. I am experiencing a problem in that we cannot access FTP sites over the Internet.
interface FastEthernet0
description LAN Link
ip address 202.154.226.225 255.255.255.248
ip nat inside
ip virtual-reassembly
speed auto
interface Serial0
description ISP Link
ip address 202.154.201.54 255.255.255.252
ip nat outside
encapsulation frame-relay IETF
frame-relay map ip 202.154.201.53 129
frame-relay interface-dlci 102
ip default-gateway 202.154.201.54
ip classless
ip route 0.0.0.0 0.0.0.0 202.154.201.53
no ip http server
ip nat inside source list 1 interface FastEthernet0 overload
access-list 1 permit 0.0.0.7 255.255.255.248
thisisshanky
Level 11
Level 11
Typically you use the WAN IP for NAT/PAT, why are you using the LAN IP for NAT/PAT ?
I dont see an ACL applied to the interface. You will need to enable CBAC (IOS FW feature set required) or else try using passive FTP.
Here is an example config.
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_configuration_example09186a008009445f.shtml
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
I am using the LAN IP as I was having trouble connecting to the ISP and posted a message here. The reply advised me to set up router as posted in this conversation.
Any recommendations?
Thought I would post the network topology.
I have not changed any config settings however on our internal network we have a Cisco 3550 switch with VLANs
VLAN100 10.10.0.254
VLAN200 10.2.0.254
VLAN100 is our server vlan and the 10.10.0.0 subnet can access FTP services but the 10.2.0.0 subnet cannot.
