MPLS BGP to p2p static failover
mohsin7666
Sir,
I have 2 ISP connection in my Infra and primary is MPLS who working on BGP protocol and secondry is Point 2 point who is working on Static route. I need to do a fail-over between BGP to static vice versa
Thanks regard
Mohsin Hiroli
Julio E. Moisa
You could use IP SLA + tracking + EEM Scripting, or you could configure the static route with higher administrative distance than received by the MPLS.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
5 Replies 5
Julio E. Moisa
Sir,
when i configure the static route with higher administrative distance it will take 60 sec delay to switch the line is the another way to decrease the down time.
Try to include this command line under the BGP peering:
neighbor ip-address fall-over
https://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/cs_bsfda.html
mahditalebi
Dear Mohsin,
Please consider that the type of connection is not important in this scenario and what you should consider is routing. Since BGP has two administrative distances (20 for eBGP and 200 for iBGP), according to your destination that you have a route for, you can assign an administrative distance to your static route, as bellow:
Static route with ADStatic route with ADHTH,
Mahdi
Thanks for your support sir
when i try this solution fail-over will take 60 sec to switch the line.
any other way to fix 60 sec delay time out..
