MPLS Deployment Basics Steps (Production)
nwekechampion
Level 3
Level 3
Hi all,
My organization has been recently flirting with the idea of deploying mpls for one of client's with multiple sites.
Can anyone here please, provide me with a documentation on how to go about this: From the ISP vantage point to the Client's.
I know and understand basic mpls on a technical level but applying that knowledge in real-life is where I am in the dark.
Thanks all
balaji.bandi
Start with nice guide from roger
https://www.rogerperkin.co.uk/ccie/mpls/cisco-mpls-tutorial/
BB
Thanks so much  Balaji.
Will check it out.
Hello
TBH  for a L3 mpls vpn solution you wouldn't have to worry about the mpls vpn setup at all, as all this would probably be provided by your ISP via their provider edge (PE)  label switched rtrs (LSR) into its own mpls backbone.
Only what you need to do is either statically or dynamically apply some routing on your customer edge (CE)  rtrs that connect to your ISP's PE rtrs.
Kind Regards
Paul
