07-30-2023 06:51 PM
Hi all,
Just looking to understand the design concept and use-case of MPLS over DMVPN.
Why would one need to have both of them running conccurently and how does it work from high-level understanding?
My understanding of DMVPN ==> done over Internet (NBMA IP)
My understanding of MPLS ==> done over Service Provider MPLS cloud
So why merge the 2 above? What does that solve?
Champ
Solved! Go to Solution.
08-03-2023
04:44 AM
- last edited on
08-07-2023
10:29 PM
by
Translator
Hello @nwekechampion ,
I have read the document at the link you have provided
Short answer :
This is a specialized niche feature that allows to support end to end MPLS L3 VPN traffic of multiple VPNs over a single DMVPN cloud.
Long answer:
It is a specialized feature for carrying MPLS L3 VPN traffic and MPLS L3 VPN control plane ( MP BGP AF vpnv4 ) over a single DMVPN cloud.
This solution leverages on DMVPN Phase 2 where the
next hops
are left unchanged.
MP BGP Ipv4 AF can be used to advertise the BGP
next-hops
used by MP BGP
vpnv4 prefixes
A
VPNv4 prefix
includes a BGP
next-hop
one or more route targets and a
VPNv4 prefix
that is made of
RD+IPv4 prefix
A VPN label allocated by the remote PE is associated with the
VPNv4 prefix
The HUB has to act as iBGP route reflector for all address families IPv4 and VPNv4.
A Spoke A / PEA that receives traffic on an interface associated to a VRF
VRF_A1
will use the route table of the VRF to find out the BGP
next-hop
of the destination address.
The BGP
next-hop
should be the loopback of remote SpokeB / PE node.
By using knowledge from MP BGP IPv4 and NHRP Spoke A understands that it has to setup an IPSec dynamic spoke to spoke tunnel to Spoke B.
The tunnel is started and once it is operational Spoke A can send an MPLS frame to the other end of the tunnel with a single label the VPN label that has been advertised by Spoke B in VPNv4.
Spoke B examines the label to understand the VRF the packet belongs to. It strips the label and sends the packet out the VRF interface towards the destination address.
Because the dynamic tunnel is a logical direct connection between SpokeA and Spoke B and the PHP applies there is no need to use LDP to build end to end LSPs between loopback addresses of spokes.
In fact the feature does not use LDP.
The VPN traffic can travel only on direct spoke to spoke tunnel and not via the hub for what is written just above.
The advantage of this feature is that multiple VPNs can use a single DMVPN cloud compared to a VRF lite approach where each VRF would need a dedicated DMVPN cloud to achieve end to end connectivity.
The possible use case are limited to :
enteprises that want to have MPLS L3 VPNs extended between sites but the sites have only internet access links where a DMVPN cloud is implemented
Very specific feature with limited use case.
Hope to help
Giuseppe
07-30-2023 08:51 PM
They different technologies that do completely different things. They are not mutually exclusive. What if an ISP has a HUB/Spoke topology that they are running MPLS on and want to incorporate DMVPN. You can have both or neither in any environment.
DMVPN simplifies the HUB/Spoke topology setup while requiring minima configuration and MPLS uses labels to forward so the underlying transport can be more than just IP.
Hope that helps
-David
07-30-2023 11:14 PM
Hello
The main reason would be to have resilience, MPLS would be the main circuit and the DMVPN would be the back up, or maybe you have a part of the network that needs to be segregated from the mpls service that but not at the cost of running mpls.
08-03-2023 03:13 AM
So sorry guys, I have read both comments several times and still don't understand why and how MPLS would co-exist with DMVPN.
I have read the below a few times too, but Cisco docs ae notoriously terrible at explaining advanced concept like these in a easy to understand manner.
@paul driver .. are you referring to an enterprise having 2 transports (MPLS and WAN) ? Not sure that is what the above doc refers to
@David Ruess could you maybe break this down a little bit, how exactly DMVPN achieves that "minimal config"
08-03-2023
04:44 AM
- last edited on
08-07-2023
10:29 PM
by
Translator
Short answer :
Long answer:
next hops
are left unchanged.
next-hops
used by MP BGP
vpnv4 prefixes
A
VPNv4 prefix
includes a BGP
next-hop
VPNv4 prefix
that is made of
RD+IPv4 prefix
VPNv4 prefix
VRF_A1
next-hop
The BGP
next-hop
Hope to help
Giuseppe
08-07-2023 01:32 AM
Thank you
