OSPF troubleshooting
almas1989
Hello, Good Day
I'm new to learning OSPF and made a simple lab in packet tracer and im facing an issue i have two switches connected with core by ospf point to point links 1 switch is connected and i can see it as neighbor but 2nd switch i cant see in ospf neighbor.
below is configuration from all 3 switches
switch 1
interface GigabitEthernet1/1/1
no switchport
ip flow egress
ip flow ingress
ip address 10.105.255.2 255.255.255.252
ip ospf network point-to-point
ip ospf hello-interval 5
ip ospf dead-interval 20
ip ospf priority 1
router ospf 911
router-id 10.252.5.11
log-adjacency-changes
redistribute connected subnets
passive-interface default
no passive-interface GigabitEthernet1/1/1
no passive-interface Vlan85
network 10.105.255.2 0.0.0.0 area 5
switch 2 (this switch is not becoming neighbor with switch 3)
no switchport
ip flow egress
ip flow ingress
ip address 10.105.255.3 255.255.255.248
ip ospf priority 1
router ospf 911
router-id 10.252.5.12
network 10.105.255.10 0.0.0.0 area 5
switch 3 core
interface GigabitEthernet1/1/4
no switchport
no ip address
ip ospf priority 1
router ospf 911
router-id 10.252.18.0
no passive-interface GigabitEthernet1/1/2
no passive-interface GigabitEthernet1/1/3
no passive-interface GigabitEthernet1/1/4
network 10.105.255.0 0.0.0.3 area 5
network 10.117.255.0 0.0.0.3 area 17
network 10.118.255.0 0.0.0.3 area 18
any help would be appreciated thanks in advance.
Giuseppe Larosa
Hello @almas1989 ,
there is a subnet mask mismatch
switch 1
switch2:
fix it or both use the /30 or both use /29 subnet mask
Hope to help
Giuseppe
Giuseppe Larosa
Hello @almas1989 ,
switch 1
switch2:
Hope to help
Giuseppe
Maybe I missed it but R3 doesn't have any IP addresses. If you're trying to form a neighborship you need an IP address on an interface in the same subnet to accomplish this.
Joseph W. Doherty
As a side question, why are you redistributing connected subnets?
almas1989
Thanks for helping me out, issue resolved after adding
10.105.255.5 255.255.255.252 on switch 2 and 101.05.255.6 255.255.255.252 on switch 3/core
