MPLS VPN Lab problem with redistribution of CE OSPF networks from the PE
David_Mitchell
Hi all,
I have been creating a GNS3 lab for MPLS VPN and I have the whole thing working end-to-end except that I can't get the PE to redistribute OSPF into BGP
As far as I can see I am doing this correctly but the only network that is redistributing across the WAN is the directly connected network between the CE and PE!
Same for both sides so if we can get PE1 side working I can just mirror the cfg for PE2
I have attached the GNS topology drawing and configs
Please let me know if you need anything more
Thanks in advance
Mitchell
Jon Marshall
David
Can you post from PE1 -
1) "sh ip route vrf  RED"
2) "sh ip bgp"
Jon
Apologies Jon, since the forum format has changed I am seeing two streams for this same post.
I have resolved the issue, if you can some how see what I cannot, you will find the solution (if your interested) if you can't and you are still interested in the answer I would be happy to email you
Thanks also for a quick reply on this
Mitchell
Mitchell
No problem.
I read the other post as well and saw you had solved it.
Jon
