MPLS VPN Lab problem with redistribution of CE OSPF networks from the PE
David_Mitchell
Hi all,
I have been creating a GNS3 lab for MPLS VPN and I have the whole thing working end-to-end except that I can't get the PE to redistribute OSPF into BGP
As far as I can see I am doing this correctly but the only network that is redistributing across the WAN is the directly connected network between the CE and PE!
Same for both sides so if we can get PE1 side working I can just mirror the cfg for PE2
I have attached the GNS topology drawing and configs
Please let me know if you need anything more
Thanks in advance
Mitchell
5 Replies 5
Dragan Ilic
Level 4
Level 4
Could you put:
network 10.0.1.1 0.0.0.0 area 0
under "router ospf 10 vrf RED"
On PE1 router offcourse...
Also check same thing on PE2 please...
HTH,
Dragan
HTH,
Dragan
Hi Dragan,
It isn't the network statement as this is covered by the OSPF configuration on the fa1/0 interface itself.
I have however resolved the issue......
If interested I had to add the following to the PE routers:
PE2(config)#router bgp 65000
PE2(config-router)#address-family ipv4 vrf RED
PE2(config-router-af)#redistribute ospf 10 match external
Previously I didn't have the "match external" keywords
Cheers for the input
Mitchell
Yea great...I missed that - you did redistributed loopbacks in OSPF and they are showing as E2 by default wink
Great work...
HTH,
Dragan
HTH,
Dragan
Aha... I see why I had to add the "external keyword now"
I have done the following on the CE:
CE1(config)#router ospf 1
CE1(config-router)#no redistribute connected subnets
CE1(config-router)#network 192.168.1.0 0.0.7.255 area 0
I have don the following on the PE:
PE1(config)#router bgp 65000
PE1(config-router)#address-family ipv4 vrf RED
PE1(config-router-af)#$10 vrf RED match internal external 1 external 2
PE1(config-router-af)#redistribute ospf 10
And this has worked how I was planning from the start - All vrf RED routes redistributed from the CE OSPF showing as standard OSPF O routers and not extenal as before.
Thanks for the insight Dragan, much appreciated
Mitchell
Yes that's the reason behind "external"...great...keep up with good labs wink
BR,
Dragan
HTH,
Dragan
