Unable to open some of the websites
Hi Team,
I have Cisco 3825 router and configured a Gig0/0 for the internet link. Recently we have observed that some of the sites like facebook/sbi/supportforums.cisco.com not opening. Whereas i am able to open all other sites like cisco.com/twitter.com
Can someone please help me on this
interface GigabitEthernet0/1
 mtu 1500
 ip address x.x.x.x. 255.255.255.252
 ip virtual-reassembly
 no ip route-cache cef
 no ip route-cache
 ip tcp adjust-mss 1450
 load-interval 30
 duplex auto
 speed auto
 media-type rj45
 hold-queue 524 in
 hold-queue 524 out
router bgp xxxx
 bgp log-neighbor-changes
 neighbor x.x.x.x remote-as x.x.x.x
 neighbor  update-source GigabitEthernet0/1
  maximum-paths 2
MAC
Regards MAC
8 Replies 8
Nish Vamadevan
It may be an MTU issue... Have you tried changing the MTU to reflect the one set by your ISP?
Hi Nish,
Yes i have tried changing the MTU and also the tcp MSS value but no luck
Will changing the value in Weight will do any difference?
neighbor x.x.x.x weight 550
MAC
Regards MAC
How many BGP peers do you have? 1?
Weight is locally significant and also check the hold-queue, as "Cisco recommends that the queue size not exceed ten packets on asynchronous interfaces"
I would do a packet capture and see whats going on...
Hi Nish,
We have only one BGP Peers, some few days back we were having two but i have removed the unwanted configuration.
As of now MTU size is 1500, i tried changing it but no luck
Asif C Y
Regards MAC
Can you please explain why the following is there...? Have a packet capture and see whats going on...
router bgp xxxx
  maximum-paths 2
Hi Nish,
The config you are referring has been removed for now and tested. But no proper results, i am trying to run debug commands and take results
Asif C Y
Regards MAC
Can you try TCP MSS to 1452 and double check the MTU, I really think one of them is causing it...
I do not know that it would cause this problem but I question why this is configured on the interface
Using CEF usually improves performance and when you turn it off you should result in all packets being process switched which does impact performance.
I also wonder why this is on the interface
and it makes me think that fragmentation and reassembly may be the issue. As a test I suggest that you use the ip tcp adjust-mss to 1300 and see if the behavior changes.
Rick
Rick
