Multicast Dilemmas. Help!
Andrew WEISS
Hi all, we've been experiencing some multicast problems and I'm hopeful that the experts out there can give me a hand figuring them out before I decide to throw in the towel and put in place GRE tunneling.
Some facts about our network:
  • Each of our PE has at least 3 uplinks to at least 2 different Pops.
  • Each PE receives about  90k BGP routes from our 4 route-reflectors with a default route (0/0) for any missing specific routes.
  • Each PE receives about 3k  multicast routes from our 4 route-reflectors with a default route (0/0) for any missing specific routes.
  • ISISI is our IGP (L1 only, multitopology -- IPv6 unicast/multicast is running as well on all PE with the full ipv6 table (18k))
  • RFP check is running on all backbone line in loose mode (ip verify unicast source reachable-via any)
  • PIM sparse mode is active on all backbone links.
  • There are multiple paths with equal cost metrics on all backbone links and inbound/outbound traffic is not symmetrical (...yes I know)
  • There are 2 anycast RP (one in the north and the second in the south).  IGP metrics determine which is used.
The problem...
One of our clients it trying to join a group but he's having problems doing so.  The configuration of his interface is correct.
From the PE he is connected to as well as within our lab, I can join the group that he is interested in on the router using igmp:
LAB-NOC-7200-GATEWAY(config-subif)#ip igmp join-group 233.29.151.44
LAB-NOC-7200-GATEWAY#sh ip igmp groups
IGMP Connected Group Membership
Group Address    Interface                Uptime    Expires   Last Reporter   Group Accounted
233.29.151.44    GigabitEthernet0/2.431   00:00:10  00:02:49  193.51.177.0
224.0.1.40       GigabitEthernet0/2.431   1w1d      00:02:58  193.51.177.0
The MROUTE results are coherent:
LAB-NOC-7200-GATEWAY#sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group,
       V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 233.29.151.44), 00:02:48/stopped, RP 193.51.178.254, flags: SJPL
  Incoming interface: Tunnel650580, RPF nbr 193.51.177.6
  Outgoing interface list: Null
(202.158.196.68, 233.29.151.44), 00:01:39/00:02:57, flags: PLT
  Incoming interface: Tunnel650580, RPF nbr 193.51.177.6, Mbgp
(202.158.195.196, 233.29.151.44), 00:01:41/00:02:58, flags: PLT
(129.78.221.17, 233.29.151.44), 00:01:43/00:02:59, flags: PLT
(202.6.112.4, 233.29.151.44), 00:01:46/00:02:57, flags: PLT
(202.158.196.134, 233.29.151.44), 00:01:46/00:02:57, flags: PLT
(202.158.195.132, 233.29.151.44), 00:01:48/00:02:55, flags: PLT
(202.158.196.4, 233.29.151.44), 00:01:48/00:02:58, flags: PLT
(202.158.195.68, 233.29.151.44), 00:01:48/00:02:53, flags: PLT
(138.77.139.71, 233.29.151.44), 00:01:48/00:02:53, flags: PLT
(138.77.155.72, 233.29.151.44), 00:01:48/00:02:58, flags: PLT
(131.172.135.210, 233.29.151.44), 00:01:49/00:02:58, flags: PLT
(203.27.221.247, 233.29.151.44), 00:01:49/00:02:59, flags: PLT
(131.172.8.214, 233.29.151.44), 00:01:49/00:02:56, flags: PLT
(202.158.195.4, 233.29.151.44), 00:01:51/00:02:58, flags: PLT
(195.220.53.138, 233.29.151.44), 00:01:51/00:02:59, flags: PLT
(134.129.95.122, 233.29.151.44), 00:01:51/00:02:58, flags: PLT
(138.77.147.71, 233.29.151.44), 00:01:51/00:02:59, flags: PLT
(*, 224.0.1.40), 1w1d/00:02:17, RP 0.0.0.0, flags: DPL
  Incoming interface: Null, RPF nbr 0.0.0.0
The mulitcast packets arrive on our lab 7200 and packets received increase.
LAB-NOC-7200-GATEWAY#sh ip mroute count
IP Multicast Statistics
19 routes using 6536 bytes of memory
2 groups, 8.50 average sources per group
Forwarding Counts: Pkt Count/Pkts(neg(-) = Drops) per second/Avg Pkt Size/Kilobits per second
Other counts: Total/RPF failed/Other drops(OIF-null, rate-limit etc)
Group: 233.29.151.44, Source count: 17, Packets forwarded: 0, Packets received: 8248
  RP-tree: Forwarding: 0/0/0/0, Other: 0/0/0
  Source: 202.158.195.132/32, Forwarding: 0/-1/0/0, Other: 398/0/398
  Source: 202.158.195.4/32, Forwarding: 0/-2/0/0, Other: 499/0/499
  Source: 138.77.147.71/32, Forwarding: 0/-1/0/0, Other: 630/0/630
  Source: 129.78.221.17/32, Forwarding: 0/-1/0/0, Other: 450/0/450
  Source: 202.6.112.4/32, Forwarding: 0/-2/0/0, Other: 492/0/492
  Source: 202.158.195.196/32, Forwarding: 0/-3/0/0, Other: 468/0/468
  Source: 202.158.195.68/32, Forwarding: 0/-1/0/0, Other: 397/0/397
  Source: 195.220.53.138/32, Forwarding: 0/-4/0/0, Other: 539/0/539
  Source: 131.172.135.210/32, Forwarding: 0/-2/0/0, Other: 458/0/458
  Source: 203.27.221.247/32, Forwarding: 0/-1/0/0, Other: 398/0/398
  Source: 138.77.139.71/32, Forwarding: 0/-1/0/0, Other: 398/0/398
  Source: 131.172.8.214/32, Forwarding: 0/-1/0/0, Other: 537/0/537
  Source: 134.129.95.122/32, Forwarding: 0/-2/0/0, Other: 748/0/748
  Source: 138.77.155.72/32, Forwarding: 0/-2/0/0, Other: 443/0/443
  Source: 202.158.196.134/32, Forwarding: 0/-1/0/0, Other: 473/0/473
  Source: 202.158.196.4/32, Forwarding: 0/-1/0/0, Other: 458/0/458
  Source: 202.158.196.68/32, Forwarding: 0/-2/0/0, Other: 462/0/462
Group: 224.0.1.40, Source count: 0, Packets forwarded: 0, Packets received: 0
------------------------------------------------------DEBUG-----------------------------------
LAB-NOC-7200-GATEWAY#debug ip mpacket
IP multicast packets debugging is on
LAB-NOC-7200-GATEWAY#term
LAB-NOC-7200-GATEWAY#terminal moni
LAB-NOC-7200-GATEWAY#terminal monitor
LAB-NOC-7200-GATEWAY# (Tunnel650580) d=233.29.151.44 id=0, ttl=113, prot=17, len=40(40), mroute olist null
Nov  6 11:15:13: IP(0): s=203.27.221.247 (Tunnel650580) d=233.29.151.44 id=0, ttl=109, prot=17, len=547(547), mroute olist null
Nov  6 11:15:13: IP(0): s=202.158.196.134 (Tunnel650580) d=233.29.151.44 id=0, ttl=113, prot=17, len=40(40), mroute olist null
Nov  6 11:15:13: IP(0): s=202.158.196.68 (Tunnel650580) d=233.29.151.44 id=0, ttl=111, prot=17, len=170(170), mroute olist null
Nov  6 11:15:13: IP(0): s=195.220.53.138 (Tunnel650580) d=233.29.151.44 id=1682, ttl=116, prot=17, len=81(81), mroute olist null
Nov  6 11:15:13: IP(0): s=131.172.135.210 (Tunnel650580) d=233.29.151.44 id=2118, ttl=109, prot=17, len=550(550), mroute olist null
Nov  6 11:15:13: IP(0): s=134.129.95.122 (Tunnel650580) d=233.29.151.44 id=43998, ttl=112, prot=17, len=40(40), mroute olist null
Nov  6 11:15:13: IP(0): s=129.78.221.17 (Tunnel650580) d=233.29.151.44 id=0, ttl=106, prot=17, len=97(97), mroute olist null
Nov  6 11:15:13: IP(0): s=134.129.95.122 (Tunnel650580) d=233.29.151.44 id=110, ttl=112, prot=17, len=40(40), mroute olist null
Nov  6 11:15:13: IP(0): s=134.129.95.122 (Tunnel650580) d=233.29.151.44 id=19326, ttl=112, prot=17, len=40(40), mroute olist null
Nov  6 11:15:13: IP(0): s=134.129.95.122 (Tunnel650580) d=233.29.151.44 id=16680, ttl=112, prot=17, len=62(62), mroute olist null
---------------------------------------------------------------END DEBUG-------------------------------------------------------------------
However, if I mtrace the destination I get stuck on our  paris1 router.
------------------------------------------------------MTRACE-------------------------------------
LAB-NOC-7200-GATEWAY#mtrace 202.6.112.4 193.51.178.198 233.29.151.44
Mtrace from 202.6.112.4 to 193.51.178.198 via group 233.29.151.44
From source (?) to destination (?)
Querying full reverse path... * switching to hop-by-hop:
0  193.51.178.198
-1  193.51.178.198 PIM/MBGP  [202.6.112.0/24]
-2  tu650580-paris1-rtr-032.noc.renater.fr (193.51.177.6) PIM  [202.6.112.0/24]
-3  * * * gi8-3-paris1-rtr-021.noc.renater.fr (193.51.177.154)
On paris1 the routing is fine, or so it would seem
-----------------------------------------------Paris1 routing-----------------------------------------------------------------------
paris1-rtr-021#sh ip mroute 233.29.151.44
       T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
(*, 233.29.151.44), 00:08:37/00:02:43, RP 193.51.178.254, flags: S
  Incoming interface: GigabitEthernet8/8, RPF nbr 193.51.177.159
    GigabitEthernet8/3, Forward/Sparse, 00:08:37/00:02:43
(202.158.206.38, 233.29.151.44), 00:00:44/00:02:45, flags:
  Incoming interface: TenGigabitEthernet2/1, RPF nbr 193.51.177.26, Mbgp
    GigabitEthernet8/8, Forward/Sparse, 00:00:44/00:02:45
    GigabitEthernet8/3, Forward/Sparse, 00:00:44/00:02:15
(137.219.15.25, 233.29.151.44), 00:00:45/00:02:44, flags:
    GigabitEthernet8/8, Forward/Sparse, 00:00:45/00:02:44
    GigabitEthernet8/3, Forward/Sparse, 00:00:45/00:02:14
(203.27.221.247, 233.29.151.44), 00:08:37/00:02:40, flags: T
(202.158.196.134, 233.29.151.44), 00:08:37/00:02:53, flags: T
(202.158.196.68, 233.29.151.44), 00:08:37/00:02:50, flags: T
(202.158.196.4, 233.29.151.44), 00:08:37/00:02:43, flags: T
(202.158.195.196, 233.29.151.44), 00:08:37/00:02:48, flags: T
(202.158.195.132, 233.29.151.44), 00:08:37/00:02:42, flags: T
(202.158.195.68, 233.29.151.44), 00:08:39/00:02:37, flags: T
    GigabitEthernet8/3, Forward/Sparse, 00:08:39/00:02:42
(202.158.195.4, 233.29.151.44), 00:08:39/00:02:41, flags: T
(202.6.112.4, 233.29.151.44), 00:08:39/00:02:50, flags: T
(195.220.53.138, 233.29.151.44), 00:08:39/00:02:38, flags: T
(138.77.155.72, 233.29.151.44), 00:08:39/00:02:42, flags: T
(138.77.147.71, 233.29.151.44), 00:08:39/00:02:41, flags: T
(138.77.139.71, 233.29.151.44), 00:08:39/00:02:37, flags: T
(134.129.95.122, 233.29.151.44), 00:08:39/00:02:42, flags: T
(131.172.135.210, 233.29.151.44), 00:08:39/00:02:38, flags: T
(131.172.8.214, 233.29.151.44), 00:08:39/00:02:41, flags: T
(129.78.221.17, 233.29.151.44), 00:08:39/00:02:51, flags: T
MTRACES on all of our PE seem to providing similar results and messages --
Timed out receiving responses
Perhaps no local router has a route for source,
the receiver is not a member of the multicast
group or the multicast ttl is too low.
In short, it's not possible to mtrace on any of our PE.   Anyone have an idea what could be the problem and what would be a possible fix for this problem.
0 Replies 0
