Multicast -- Multicast VPN --- XRv
Would like your assistance please regarding below quesitos
1- As you know to verify multicast we can use ping.
My problem is that when you ping using source loopback address it does not work [spare-mode is configured normally under loopback] however when you configure using outgoing interface it pings normally
What could be the reason for this ?
2- Does XRv simulator works fine with multicast. I am having very strange behavior is that OIL list is always null although source is directly connected. Not sure if its a bug or XRv issue
R8#ping 227.7.7.7 repeat 10
Sending 10, 100-byte ICMP Echos to 227.7.7.7, timeout is 2 seconds:
R8#
RP/0/0/CPU0:XR2#show pim topology
Thu May 22 06:14:34.625 UTC
IP PIM Multicast Topology Table
Entry state: (*/S,G)[RPT/SPT] Protocol Uptime Info
Entry flags: KAT - Keep Alive Timer, AA - Assume Alive, PA - Probe Alive
    RA - Really Alive, IA - Inherit Alive, LH - Last Hop
    DSS - Don't Signal Sources,  RR - Register Received
    SR - Sending Registers, SNR - Sending Null Registers
    E - MSDP External, EX - Extranet
    MFA - Mofrr Active, MFP - Mofrr Primary, MFB - Mofrr Backup
    DCC - Don't Check Connected, ME - MDT Encap, MD - MDT Decap
    MT - Crossed Data MDT threshold, MA - Data MDT Assigned
    SAJ - BGP Source Active Joined, SAR - BGP Source Active Received,
    SAS - BGP Source Active Sent, IM - Inband mLDP
Interface state: Name, Uptime, Fwd, Info
Interface flags: LI - Local Interest, LD - Local Dissinterest,
    II - Internal Interest, ID - Internal Dissinterest,
    LH - Last Hop, AS - Assert, AB - Admin Boundary, EX - Extranet,
    BGP - BGP C-Multicast Join, BP - BGP Source Active Prune,
    MVS - MVPN Safi Learned, MV6S - MVPN IPv6 Safi Learned
(*,224.0.1.40) DM Up: 00:56:21 RP: 0.0.0.0
JP: Null(never) RPF: Null,0.0.0.0 Flags: LH DSS
  Loopback0                   00:56:21  off LI II LH
  GigabitEthernet0/0/0/2      00:56:14  off LI LH
(*,227.7.7.7) SM Up: 00:29:15 RP: 20.20.20.20*
JP: Join(never) RPF: Decapstunnel3,20.20.20.20 Flags:
  GigabitEthernet0/0/0/2      00:29:15  fwd Join(00:03:13)   <<--- receiver sends PIM Join normally
(10.8.20.8,227.7.7.7)SPT SM Up: 00:00:03
JP: Join(00:00:46) RPF: GigabitEthernet0/0/0/0.820,10.8.20.8* Flags: KAT(00:03:29) RA RR (00:04:33)
  No interfaces in immediate olist   <<<<<------
Appreciate your assistance
Sherif Ismail
Cuong Nguyen
Hi Sherif Ismail,
I encountered this and checked around. It seems that XRv supports Control-Plane features fully - BGP/IGP/LDP/PIM/etc. will work. However, Data-plane is supported with limitations.
Cheers,
Cuong.
I just installed XRv 5.2.0. Shall I expect MVPN data plane work?
Ato
