Multicast routing - did something changed ?
impi
Hi All,
i used to configure multirouting with no problem. Here i have to do it one more time and nothing works, i do not know why.
Then i fall back to a very simple config : multicast routing between 2 routed interfaces on the same router -> same problem, nothing OK
My test :
a C921 configured on gig4 (192.168.4.254) and gig5 (192.168.5.254)
One pc on 192.168.4.1 and another on 192.168.5.1
No firewall
w10
iperf/vlc/self made program to test multicast
debug ip igmp we can see some info like :
*Jan 24 15:58:00.931: IGMP(0): Received v2 Report on GigabitEthernet4 from 192.168.4.1 for 228.1.1.1
*Jan 24 15:58:00.931: IGMP(0): Received Group record for group 228.1.1.1, mode 2 from 192.168.4.1 for 0 sources
*Jan 24 15:58:00.931: IGMP(0): WAVL Insert group: 228.1.1.1 interface: GigabitEthernet4Successful
*Jan 24 15:58:00.931: IGMP(0): Switching to EXCLUDE mode for 228.1.1.1 on GigabitEthernet4
*Jan 24 15:58:00.931: IGMP(0): Updating EXCLUDE group timer for 228.1.1.1
*Jan 24 15:58:00.931: IGMP(0): MRT Add/Update GigabitEthernet4 for (*,228.1.1.1) by 0
*Jan 24 15:58:01.113: IGMP(0): Received v2 Report on GigabitEthernet4 from 192.168.4.1 for 228.1.1.1
*Jan 24 15:58:01.113: IGMP(0): Received Group record for group 228.1.1.1, mode 2 from 192.168.4.1 for 0 sources
*Jan 24 15:58:01.113: IGMP(0): Updating EXCLUDE group timer for 228.1.1.1
*Jan 24 15:58:01.113: IGMP(0): MRT Add/Update GigabitEthernet4 for (*,228.1.1.1) by 0
*Jan 24 15:58:11.497: IGMP(0): Received Leave from 192.168.4.1 (GigabitEthernet4) for 228.1.1.1
*Jan 24 15:58:11.497: IGMP(0): Received Group record for group 228.1.1.1, mode 3 from 192.168.4.1 for 0 sources
*Jan 24 15:58:11.497: IGMP(0): Lower expiration timer to 2000 msec for 228.1.1.1 on GigabitEthernet4
*Jan 24 15:58:11.497: IGMP(0): Send v2 Query on GigabitEthernet4 for group 228.1.1.1
*Jan 24 15:58:12.583: IGMP(0): Send v2 Query on GigabitEthernet4 for group 228.1.1.1
*Jan 24 15:58:13.583: IGMP(0): Switching to INCLUDE mode for 228.1.1.1 on GigabitEthernet4
*Jan 24 15:58:13.583: IGMP(0): MRT delete GigabitEthernet4 for (*,228.1.1.1) by 0
Nothing on debug ip mpacket
version is flash:c900-universalk9-mz.SPA.158-3.M2.bin
Bellow is the conf :
ip multicast-routing
ip cef
no ipv6 cef
redundancy
interface Loopback0
 ip address 10.254.1.1 255.255.0.0
 ip pim sparse-dense-mode
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 ip address 192.168.4.254 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet5
 ip address 192.168.5.254 255.255.255.0
 duplex auto
 speed auto
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip pim rp-address 10.254.1.1
Any help, debug or so will be really appreciated, i do not know what change into multicast config !
johnd2310
Level 8
Level 8
How are you sending the multicast? Is the server vlc and the client vlc? Have you checked ttl values of the stream? Have you checked it is not a client/server issue? Install wireshark on the server and client. Check that the server is actually sending and what values it is using.Check that the client is actually trying to join the correct group.
On the router what is the output of the following commands:
show ip mroute
show ip mroute active
show ip igmp groups
show ip igmp snooping
show ip igmp snooping groups
John
**Please rate posts you find helpful**
5 Replies 5
johnd2310
Level 8
Level 8
show ip mroute
show ip igmp groups
John
Hi John, and thanks for your interest
Here is replies to your post :
 - we use vlc, iperf and a program we have done that is actually working on the config we want to replace (and that i configure myself some yers ago, i did some multicats routing config some times ago with no problem )
 - yes we tried with vlc server and client
 - ttl from our program is set to 8 (i do not know for vlc and iperf, i'll check with wireshark)
 - we tried the same test when both PC were connected directly with a network cable : all is ok.
 - with wireshark we can see multicats beeing generated, but nothing on the other side
Below are the content of the commands you asked
We did the test on IP 228.0.0.1, results seems to be weird
Iperf commands :
iperf -c 228.0.0.1 -u -t 3 -T 10
iperf -s -B 228.0.0.1 -u -t 3
sh ip mroute
(*, 228.0.0.1), 00:04:16/stopped, RP 10.254.1.1, flags: SPF
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list: Null
sh ip mroute active
Active IP Multicast Sources - sending >= 4 kbps
show ip igmp groups
IIGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter Group Accounted
239.255.255.250 Vlan1 00:26:22 00:02:26 192.168.1.1
239.255.255.250 Vlan2 00:28:41 00:02:34 192.168.2.1
228.0.0.1 Vlan2 00:04:19 00:02:30 192.168.2.1
224.0.1.40 Loopback0 00:29:30 00:02:56 10.254.1.1
sh ip igmp snoop
Global IGMP Snooping configuration:
IGMP snooping : Enabled
IGMPv3 snooping support : Basic
Report suppression : Enabled
Last Member Query Interval : 1000
Vlan 1:
IGMPv2 immediate leave : Disabled
Multicast router learning mode : pim-dvmrp
CGMP interoperability mode : IGMP_ONLY
Vlan 99:
sh ip igmp snoop group
Vlan Group Version Port List
1 239.255.255.250v2 Fa1
2 228.0.0.1 v2 Fa2
2 239.255.255.250v2 Fa2
Really we do not know what happens
Many thanks for your help
edit : in fact we saw that even with "T 10" options in iperf, ttl seems to remain to 1 (seen on wireshark...)
Do you have a good testing program ? We are searching, only find iperf and vlc and nothing else (on windows)
it seems now better that i have a real good program to test multicast :)
so old, but so simple !
https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/Multicast-Testing-Tool/td-p/448210
http://www.dqnetworks.ie/toolsinfo/mcasttest/
I'll now do my full tests and tell you
The issue is the TTL from VLC (default is 1) so change the value in the app.
VLC-Preferences—>Stream output—> access output—> hop limit
Thanks to both of you for your help.
with the program i found all is ok now (and more simple than vlc or iperf :))
Now i hav problem with hsrp and multicast :(
Found many docs but do not understand all... i will open a new thread for that
Once again, many thanks !
